460 blocks
Old Sep 28, 2008 | 08:34 PM
bagmo's Avatar
bagmo
460 blocks
Can anyone explain the difference between a car block and truck block bolt pattern on motor mounts. I know the motor mounts change depending on application.
Old Sep 28, 2008 | 09:16 PM
tenforty_2's Avatar
tenforty_2
The "blocks" are going to be the same with regards to "bolt pattern". Maybe you are looking for something else? Not sure. Also, look around on here there are specific forums for specific topics. For example, 385 bb forum will cover questions about the 460 engine. Welcome to the site I know you will find it very helpful.
Old Sep 28, 2008 | 10:54 PM
BrentNewland's Avatar
BrentNewland
You can try 460ford.com, but everything I've heard says that the car and truck blocks for the 460 in the same year are pretty much identical externally.
