Delete EGR?
Old Sep 28, 2008 | 03:20 PM
78bigunns's Avatar
78bigunns
Delete EGR?
I've been thinking about just cutting off the EGR tube and not bothering to get one from the yard and welding it too me headers to get the EGR to work.
I have no emissions here, was wondering the possible issues I could have by doing this mechanically?
I would leave everything in place, I just wouldn't tap into the headers.....
IF it's a must I will do it, just not feeling like going to a yard, pulling one of to weld to the headers, yada, yada.
Thoughts...............
Thanks
Old Sep 28, 2008 | 05:22 PM
Truckin4life's Avatar
Truckin4life
Street Queen to the extr3m3
Ford Fuel Injection
Do some searching there.....
You will find a kit to tell the comp the egr is working, and to block off the egr stuff too.
Old Sep 29, 2008 | 08:29 PM
zooom's Avatar
zooom
There'll be no issues mechanically but the function of the EGR system is to lower the combustion gas temperatures (in the cylinder) by diluting the intake air charge with exhaust gases. If you remove the EGR component from the combustion cycle, the engine will run hotter, perhaps even knock under load, & now-a-days, won't run any better or economically than if you left the EGR system connected [the engine computer takes care of the diminished intake charge (with EGR-provided gases present) to provide a stoiciometric fuel/air/exhaust gas charge to make the engine run at its best].
Leave it connected....
Old Sep 29, 2008 | 11:51 PM
Truckin4life
Yes... That is very true... But if he has headers that dont have the connection for it, then what is he to do?
Old Sep 30, 2008 | 02:02 PM
Bear River's Avatar
Bear River
Former ******
Simple, get smog legal headers. That doesn't help him if he already has headers that won't work, but that is why many professions do not order or install headers that do not retain smog equipment. You can always plug an EGR is you don't need it, but it is tricky to add if you do.
My advise would be to figure how to attach the EGR stuff to the new headers. The EGR does not hurt power, but NOX from high combustion temperatures can.
Old Sep 30, 2008 | 03:56 PM
78bigunns's Avatar
78bigunns
Thanks for all the input.
I guess Ill go ahead and weld in a Egr tube.
I was just thinking it would be way easier to just bolt up the headers as is.
FWIWm, I may have missed it, but there were no longtubes with provisions for EGR and AIR for my 96'.
Shorties there were a couple options.
I'll get a piece like Conanski suggested, and do it right...................
Old Oct 1, 2008 | 12:00 AM
Truckin4life
I was in the same position as you... No smog legal long tubes for my truck, and the shorties did nothing for the motor... So i ditched the egr and went long tubes... This truck is getting parked soon though... Going to be getting a nicely built winnie in it...
With maybe a little extra air in the cylinders.... If you catch my drift
