I am looking to buy a second set of wheels for my 2006 F350 DRW. It is a cab/chassis with a utility body and 17" wheels. I am quite sure the bolt pattern is 8x200. How can I determine if another wheel is 8x200 and not 8x170? Anything else I might need to know would be appreciated.
You want to measure the lugs that are directly across from each other, center of hole to center of hole. Meaning measure the lug that is at the 9 o'clock position to the lug that's at the 3 o'clock position.
Or, 12 o'clock to 6 o'clock.
