fuel gage sensor?
Old Sep 27, 2008 | 08:22 PM
Ryan AKL's Avatar
Ryan AKL
fuel gage sensor?
hi i just bought a 85 f-150 and found out the fuel gage doesnt work, is it a sensor? can anyone tell me how to fix this?
Old Sep 27, 2008 | 08:52 PM
HighdefJoe's Avatar
HighdefJoe
No sensor. It has a float that sends the signal via what SHOULD be a yellow wire. Check the ohms at your gauge or the float itself.
Old Sep 28, 2008 | 03:46 AM
srercrcr's Avatar
srercrcr
Chronic Ford truck problem...live with it, fill up using the miles driven on the odometer. If dual tanks, you always have a spare tankful.
Old Sep 28, 2008 | 09:12 AM
Franklin2's Avatar
Franklin2
Take the wire off the sending unit, and with the key in run and someone watching the fuel gauge, ground the wire. The gauge should swing full scale in one direction. Then take the wire off ground and let it touch nothing. The gauge should swing full scale the opposite direction. If this works, then the wiring and the gauge are ok, and there is something wrong with the sending unit inside the fuel tank. I believe the other poster is correct, the wire is going to be yellow/blue or blue/yellow.
Old Sep 28, 2008 | 10:28 AM
Ryan AKL's Avatar
Ryan AKL
thanks for the help! ill check the wireing first to see if thats the problem.
