no codes huh? Might want to do a sweep under the hood for a leaking vacuum line. Those plastic lines they used are notorious for breaking or developing small leaks.
Reason I say that is I was looking for a leak in my defroster lines (the ones that run the switch) and I accidently pulled the wrong line and the engine sped up then sputtered and almost stalled.
Did you run the KOER test then?
If not run it and see what you get.
yes i ran it both ways and all i got was 11 but i kept fooling with it and somehow it came up with codes 21 and 61 both pertain to the ect sensor. i will get one tomorrow and try it thanks
