Offroad & 4x4
gear ratios
Old Jan 14, 2002 | 09:24 PM
fordtrck302's Avatar
fordtrck302
gear ratios
ok I have stock axles with 3.55 so like can i get anything better wihtout haveing to by anew axle like can i get gears ratuions in the mid 4's wth my axles
Old Jan 15, 2002 | 04:46 PM
JoeB's Avatar
JoeB
gear ratios
What Year and model is your truck?
Old Jan 15, 2002 | 06:33 PM
fordtrck302
gear ratios
I have a 1991 f-150 4x4
Old Jan 23, 2002 | 03:16 AM
77fordf250's Avatar
77fordf250
gear ratios
yo can get 4.10s or 4.56 with the 4.56 you have to change the cross shaft they run about 30 bucks but you do not need to change the carrior or anything else besides gears and cross shaft
Old Jan 23, 2002 | 03:09 PM
Cope's Avatar
Cope
gear ratios
Assuming you have the Dana 44 independent up front, which is the stock axle for your 91 f-150 4x4, your going to have problems changing to a ratio in the mid 4's. The 44 has two different height carriers available, often called carrier break, one for ratios numerically lower than 3.73 and one for ratios numerically higher than 3.92. This is because the pinion gear gets smaller as you go to a lower gear (numerically higher of course) and it simply won't reach the ring gear. Since your truck came with 3.55s you are either going to have to buy the appropriate carrier or try to find a thicker ring gear if you want a ratio like 4.56. If changing the carrier is what you decide to do in order to get the gears you want then this is a good time to purchase a full carrier replacement locker or limited slip, if you've been wanting one. However, there is no carrier break on your 8.8 axle, so changing ratio's won't be a problem for the rear.
-Cope
95 F-150 4x4
4.9L M5OD
Front Truetrac Rear Detroit
3.73 Precision Gears
Warn Premiums
4" Superlift Superunner
Old Jan 24, 2002 | 05:42 AM
rabidranger's Avatar
rabidranger
gear ratios
