leaky hubs
Old Sep 26, 2008 | 07:10 PM
FourWheel's Avatar
FourWheel
leaky hubs
i just came back from a long trip and have grease stains on my rims and the bolts on the hub are a little loose. what should i do just take apart repack with grease and put back together is this common
Old Sep 27, 2008 | 07:19 AM
alz's Avatar
alz
I would just tighten the screws back up and watch it. If it persists, pull the cap and check the o-ring.
Old Sep 27, 2008 | 07:20 AM
Lazy K's Avatar
Lazy K
Not sure what bolts you are talking about but either the grease seals are worn or the hubs were over packed with grease or there is too much play in the wheel bearings. I would replace the seals, repack with grease and adjust the wheel bearings.
Old Sep 27, 2008 | 07:52 AM
alz's Avatar
alz
I think he is talking about the screws that hold the cap on the hub.
I could be wrong.
Old Sep 27, 2008 | 11:49 AM
Lazy K's Avatar
Lazy K
I could be wrong.
No I am wrong, you are right. For some reason I was thinking two wheel drive. Your post was not shown when I replied. So FourWheel, ignore my first post. Go with Alz.
Old Sep 27, 2008 | 12:57 PM
FourWheel's Avatar
FourWheel
thanks for the reply i took it apart and checked it out looked ok put everything back together we will see
