Cam Sensor
Cam Sensor
Where is the Cam Sensor on a 97 Truck. I have one to put on but I just found out it is under recall. I can't figure out where it goes. Is it worth putting on, the part was only $28 but I don't know how to put it on.
You will need 1 10 mm socket and a short extension and ratchet. It is located in the 10 or 11 o'clock position when looking at the front of the crank pulley. Get to it from underneath. You will also need a screwdriver or similiar to pry the old one out.
Did you get the grey one or black?
