making marker lights flash
Old Sep 29, 2008 | 10:55 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Originally Posted by ygoldsberry
ohk well heres what ive come up with. You can hook the back markers up by connecting the ground to the turnsignale wire only problem there is when you hit the brakes the markers go out. Now if you try to hook the fronts up they blink way to slow and blow fuses so that didnt work out so well. I do plan to look into to it a little more and mabey looking up a woganeer wireing diagram to see what i could come up with cause i would still like to make this work. Ill keep everyone posted on what i find
I'm thinking that a trailer wiring relay should work in this instance.
The one made for Japanese vehicles to change the seperate amber turn signal and Red brake lights on the japanese vehicle into a single wire for the one bulb on the trailer.
Infact this would be the choice I'd use.
You would hook the turn signals into the trailer harness relay's turn signal wires, and the Marker lamp wires into the brake lamp input wires, and hook the brake lamp output wires to the marker lamps. Left for left, and right for right. And in this way, you could also hook up the back markers too.
Should be able to get this at any auto parts store, or trailer or towing supply.
Old Sep 29, 2008 | 10:58 PM
81-F-150-Explorer
Originally Posted by fmc400
Heavy duty flasher = electronic flasher, which I suggested using. First line:
Not all Heavy Duty Flashers were electronic. But point taken. Showing my age.
hath
Nov 1, 2015 12:08 PM
Andercomm
Escape & Escape Hybrid
Oct 14, 2015 07:21 PM
EightGodzillas
Jan 3, 2015 02:59 PM
Bazillions
May 24, 2014 03:03 PM
T_199
Apr 25, 2014 05:04 AM
