Strange Appearance
Old Sep 26, 2008 | 08:47 AM
enggass's Avatar
enggass
Strange Appearance
I am noticing since I last cleaned my truck, some wierd white-ish stuff showing up on the edge of my alloy rims. Almost a dried glue/bird crap looking, but I cannot get it off. The stuff is an off-white color... It's not all over the place on the rims, just a few select areas - just around the edge from where the tire meets the rim. Dried, hard glue is the best way to describe the texture. I cannot for the life of me figure out what it is. And why all 4 tires? I can see if I drove through something, maybe on a tire or two, but all 4? I just got this truck, and it had brand new Pirellis on it. (20" ATR). ?????
Thanks,
Steve
Old Sep 26, 2008 | 09:31 AM
rpxr400's Avatar
rpxr400
Without seeing the wheels, it sounds like a clearcoat issue. Either the clearcoat is flaking off and/or it's already off and the aluminum?? is oxidizing.
If you can get some pics up, that would help.
Old Sep 26, 2008 | 09:43 AM
alxsnmr's Avatar
alxsnmr
It is probably the oxidation of the aluminum under the clear coat because the white hard crap is oxidized aluminum. Good news is that once there the oxidation never goes deeper just stays on the surface, but it looks like crap. Polishing the rim and recoating with a quality clear coat will fix it, but because you will change out tires, that clear coat will get scratched off again.
Old Sep 26, 2008 | 10:01 AM
enggass's Avatar
enggass
Go here:
MobileMe Gallery
Click on the images to enlarge...
Steve
Old Sep 26, 2008 | 10:07 AM
2002 F350V10's Avatar
2002 F350V10
If it is under warranty have the rims replaced.Its corrosion.
Old Sep 26, 2008 | 10:11 AM
enggass's Avatar
enggass
If it's corrosion or oxidization, why would it appear out of nowhere in 1 weeks time?
Steve
Old Sep 26, 2008 | 10:30 AM
enggass's Avatar
enggass
I just showed the pics to the dealership... Corrosion. I live in Maine and it is quite common. Our guess is it was not as obvious when I first got the truck because they cleaned it up real nice prepping it for sale. No more standard warranty. My dealer suggested that I use a very fine steel wool and rub it down, then apply something called 'Mother's Polish' to it.
Any other ideas?
Steve
