need new springs
Old Sep 25, 2008 | 10:07 PM
mooncricket's Avatar
mooncricket
need new springs
so my 97 f250 needs new front springs and i was wandering if i could put f350 springs on it and if so would it give me a little lift in the front or would it still sit the same
Old Sep 26, 2008 | 02:23 AM
jarod17's Avatar
jarod17
If the F-350 is the same year range they should bolt right in. Take into consideration that if you have the TTI front axle any lift the springs give will negatively affect your tire alignment.
Old Sep 26, 2008 | 06:07 PM
rikard's Avatar
rikard
The coil springs for these trucks are rated for weight and hieght so its usually possible to increase the spring capacity without affecting the hieght. Most of the coil springs are interchangable from the F150 to F350.
regards
rikard
Old Sep 27, 2008 | 02:52 AM
mooncricket
sorry i should have added that i have leaf springs
Old Sep 27, 2008 | 03:05 AM
northern 7.3's Avatar
northern 7.3
Temporarily Deactivated
youre better off staying with proper spring packs unless you want to lift it. if you want to lift it then you need the drop brackets and steering arm, etc. i did the springs in my 91 f250, new spring packs with bushings, and u bolts for under $250 (CDN funds)from my local spring shop.. just gave them my spring code on the door sticker and good to go.
Old Sep 27, 2008 | 03:16 AM
mooncricket
well the oter reason i was thinink the f350 springs might be better is because im gonna be putting on a large front bumper and winch mount and i dont want to lose my ride hieght
