Leaking Gas Cap
Old Sep 25, 2008 | 09:04 PM
R75CS's Avatar
R75CS
Leaking Gas Cap
I replaced the old gas cap with a new one and it still leaks down the side of the truck.Upon examination of the new cap the gasket is already cracked in 3 places, this is on the rear tank.
When I looked at the fuel filler neck of the front tank it seems that the surface of the filler neck( where the gas cap gasket would mate) is flatter than the rear tank. The rear tank fuel filler neck mating surface seem indented somewhat. Weird.
Has anyone had this problem? Is a new fuel filler neck(not sure of the proper name for this part) even available? Thanks
75 camper special
360
2WD
Auto
Old Sep 25, 2008 | 10:04 PM
Balzomedic's Avatar
Balzomedic
Just did some work on my fuel tank (rear) but didn't have the same problem as you. Mine was leaking under the truck when filling.
Don't have my catalogs with me, but have you tried Blue Oval Truck Parts or LMC Truck? They both have websites and often have diagrams detailing which parts they have available. They had all the parts I needed. You might give it a try.
Old Sep 25, 2008 | 10:28 PM
fastfarmer's Avatar
fastfarmer
I had the same problem with gas leaking out of the rear tank when full. Got a new cap from LMC. POS leaked worse than the old one. Found a good cap on a parts truck I picked up.
Old Sep 27, 2008 | 02:10 PM
R75CS's Avatar
R75CS
Thanks for your replies. Blue Oval lists the "gas filler pipe" for 68-70 but not for 75.I did not see it at LMC at all.
Old Oct 3, 2008 | 03:45 PM
R75CS's Avatar
R75CS
The fuel filler neck(rear tank) has been difficult to find. I have called many junk yards.
The one I found was $225!! Does anyone have any idea where to locate this part?
Would a filler neck from another year work somehow? Thanks.
Old Oct 4, 2008 | 02:14 PM
80F100man's Avatar
80F100man
You can make anything work if you have tools & determination............I put a '94 Saturn fuel tank and made hoses for it, fuel filler cap, for my '67 Jeep Gladiator pickup once.......remember "You can do anything you put your mind to".......best thing my mama ever told me
Old Oct 4, 2008 | 02:31 PM
Balzomedic's Avatar
Balzomedic
You may be able to get a piece of universal neoprene gas hose hose to fit. Take a look and see what you need, you can get one from a parts house. May need a little silicone but you can try. You could even fabricate a little metal guard for it if the hose rubs against the frame or something.
vettman
May 30, 2012 07:50 PM
fordtrkboy88
May 18, 2011 09:41 AM
rick2184
Dec 8, 2009 06:02 PM
Rhys
Apr 21, 2004 06:29 PM
