I Need A Replacement Starter & Bendix
Old Sep 25, 2008 | 08:26 PM
matt2491's Avatar
matt2491
1964 F100 292 3spd 2wd.
The old starter and bendix finally called it quits and now I need to find a replacement. I think the local NAPA can hook me up with a new starter motor, but I don't know where I can find a new bendix drive. The old one is really worn out and needs to be replaced. For example, sometimes it stays stuck in the engaged position (like shown in pictures below), and some of the ratchet teeth are also broken...
A couple pictures for clarification:
Any help would be appreciated! Thanks --Matt
Old Sep 25, 2008 | 08:47 PM
camperspecial65's Avatar
camperspecial65
starter drives can be found NOS...its part number is B6C11350A
Miller Obsolete in NY has 2 of them
- cs65
Old Sep 25, 2008 | 09:54 PM
triplea's Avatar
triplea
If you look on ebay under item #360090646595 they have the drive for $36.50 buy it now plus $9.00 shipping. Hopes this helps.
Old Sep 26, 2008 | 12:43 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The old starter and bendix finally called it quits and now I need to find a replacement. I think the local NAPA can hook me up with a new starter motor, but I don't know where I can find a new bendix drive. The old one is really worn out and needs to be replaced. For example, sometimes it stays stuck in the engaged position (like shown in pictures below), and some of the ratchet teeth are also broken. Any help would be appreciated! Thanks --Matt
Spring on Bendix is worn, the reason is stays engaged sometimes.
B6C11350A .. Bendix Drive (Motorcraft SD9)
Since NAPA can cross Motorcraft part numbers over to the brands they sell, I'd try getting the drive from them, before paying a premium price from one a the obsolete parts dealers.
That same starter and B-drive was used on cars/trucks from 1956 thru 1964.
Besides Miller Obsolete (800-546-7278) in Binghamton NY, Green Sales (800-543-4959) has 4, McDonald's Obsolete Parts in Rockport IN (812-359-4965) has 2 and Dennis Carpenter (704-786-8139) has 2.
Old Sep 26, 2008 | 09:38 AM
JimKoz's Avatar
JimKoz
Advance Auto Parts still carries them, and you can order them through their PartsAmerica website:
While we find your parts, please enter your ZIP Code at PartsAmerica.com
MAC's Auto Parts also has them for about $33, but the part number they list is C2AZ-11350-C
ONLINE CATALOG SEARCH/ORDERING - MAC's Antique Auto Parts
Old Sep 26, 2008 | 02:34 PM
matt2491's Avatar
matt2491
What's with the ridiculous difference in price?
_____
Old Sep 26, 2008 | 03:26 PM
matt2491's Avatar
matt2491
I just called up the local NAPA store and they have a new starter motor for $65.69.
I also looked on Dennis Carpenter's website, and they have the Bendix drive for $25 + $10 shipping. Seems to be the cheapest around, and from a good name too!
Old Sep 26, 2008 | 07:28 PM
camperspecial65
How much was Miller asking for them ??? The reason I mentioned them and nobody else is they are closest to you.
As for the rest of the starter...I would keep it...typically all thats replaced by rebuilders is brushes and if you are lucky bearings...alternators are the same too...brushes are real cheap...typically under 10 bucks and easy to install...
- cs65
Old Sep 27, 2008 | 08:51 AM
NumberDummy
Originally Posted by jimkoz
MAC's Auto Parts has them, but they list C2AZ11350C as the part number
Good point, I should have checked the parts catalog application before I posted that B6C part number.
B6C11350A is used with a AUTOMATIC TRANSMISSION.
C2AZ11350C (Motorcraft SD132) is used with a STANDARD TRANSMISSION.
The OP has a STANDARD transmission in his truck, not an automatic, so B6C11350A is IN-CORRECT!
Old Oct 4, 2008 | 07:09 PM
matt2491's Avatar
matt2491
Well, it turns out that the truck lives to fight another day!
I went to pick up the new starter from NAPA and it came with a brand new bendix drive already installed! I hightailed it home, threw it in the truck, and it cranked over and started flawlessly. In fact, it turns over faster than before and fires quicker.
I actually came very close to calling them up and returning it, thinking that I would just buy a used 292 that had a starter on it for the amount I was about to spend for both the starter and bendix. Plus then I'd have a motor to rebuild on the side...
Anyways, I'm glad I went to check it out.
Old Apr 7, 2009 | 05:30 AM
Hdhunter's Avatar
Hdhunter
Trailering
_____
My question too!! I just bought one for my 64 last week. Last time I replaced the starter on this thing it cost me $19.95 at Kragen ... now they are up to $100 or more depending on where you get one! I did get mine through Mac's.
ADOR
139
Jan 17, 2020 11:39 PM
tpdaniels
92
Dec 23, 2016 08:56 PM
first today
50
Apr 25, 2011 12:20 AM
dohc_chump
Projects
Jan 22, 2011 09:33 PM
48fordcoe
Oct 14, 2009 10:14 AM
