Hello I'm New
Old Sep 25, 2008 | 11:13 AM
063FXE's Avatar
063FXE
Hello I'm New
As the title says I am new here and I was hoping for some information and help. I have a 1978 Thunderbird and I have a 351M in it. I would like to give it a little more power. I do not have very much money and I would really do not want to tear into the engine. This is the original engine and it has never been rebuilt. It has 184,000 miles on it and I do not want to damage the engine and rebuild it until I have to. It runs well and it only has a small amount of lifter tap. I was also hoping that maybe someone might have a vacuum diagram for my engine. I might be able to afford exhaust and intake and a camshaft timing set.
Thanks in advance,
Scott Williams
P.S. If anyone is wondering my username is my plate number.
Old Sep 25, 2008 | 12:10 PM
hollenjoe's Avatar
hollenjoe
get a weiand 8010 intake, a 650 cf carb, a comp cam extreme energy xe256h, streight double roller timming chain, and long tube headers, this is what i would do to a used 351m....it should help it alot
Old Sep 25, 2008 | 12:17 PM
hollenjoe's Avatar
hollenjoe
Asuming you have around 8:1 compression you will have this estimated results with the parts i mentioned:
hp:
317@5000
torque:
380@3500
hmmm not bad...
Old Sep 25, 2008 | 12:46 PM
hollenjoe's Avatar
hollenjoe
why rods? he can use his stock rods so its just crank 200 plus pistons 200....
Old Sep 25, 2008 | 06:25 PM
hollenjoe's Avatar
hollenjoe
the rods sold by TIm arent new, they are just reconditioned with arp bolts, he might as well do that on his for the fewer buck....
Old Sep 25, 2008 | 08:18 PM
Mud Rat's Avatar
Mud Rat
1.) Intake , carb, headers
2.) Add camshaft
3.) TMI 400 crank and pistons to go to 400. Recondition the stock rods.
4.) Big money
5.) My motor(See item 4)
Old Sep 30, 2008 | 10:08 AM
063FXE's Avatar
063FXE
Thank you everyone who posted. The reason that I asked about cheaped options is beacuse I have very little money and I need the car to be down as little time as possible as it is my daily driver. One reason I do not want to get into the crankshaft and pistons is beacuse of money and since the engine runs so well I do not want to mess with the bottom until I must. All in all I must admit I would rather keep it a 351 instead of switching it to a 400, just to be different I guess. Once again thank you everyone.
Scott
P.S. feimotion339 What the heck are you talking about? Are you in the right forum?
