Bed / Frame Question
Old Sep 25, 2008 | 08:23 AM
Welsch69's Avatar
Welsch69
Does anyone know if a 1978 F250 Bed will fit a 1975 F250 without having to re-drill the holes in the bed? I tried to search for the answer, but got nothing. Thanks.
Old Sep 25, 2008 | 08:28 AM
Jolly Green's Avatar
Jolly Green
I know there are guys on here that have done swaps like this that can give you a full run down. I just happened to be cruising the forum and saw your thread, so I'll give you the short answer. No. You'll have to at least redrill the holes. '78 and 79 NOT Hiboy frames are wider than '73-77.5 HiBoy frames.
ranger429's Avatar
ranger429
The frames were a different width, holes will need to be drilled.
Old Sep 25, 2008 | 08:39 AM
Welsch69's Avatar
Welsch69
Thanks guys. I had a bad feeling that it wouldn't work. Highboy beds are so dang hard to come by.
Old Sep 25, 2008 | 08:45 AM
Jolly Green
The bed could still work though. Drilling holes then welding the others closed shouldn't be a big deal. The only other issue I think you would have would be the gas filler. If you only have the in cab tank and don't have an Aux. tank on your 75, then you'll have a fuel door with nobody home. But, that's no big D, right?
Besides that, I can't think of any other issues you would have.
Anyone else?
Old Sep 25, 2008 | 11:39 AM
1977f150xlt's Avatar
1977f150xlt
you could just do some body work and hide the gas door, or simply add a aux tank, i would just re drill the holes its that simple, and good luck with it
Old Sep 25, 2008 | 04:02 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
And you have to add a piece of angle to the end of the highboy frame for the bed bracket to rest on. (thats one hole you wont have to drill)
