serious amounts of water under the passenger carpet
Old 09-25-2008, 12:11 AM
grandaddy's66's Avatar
grandaddy's66
grandaddy's66 is offline
In the process of installing my body lift, I noticed an alarming amount of water underneath the passenger carpet. So much so, that it's starting to rust out my floor plan! On a 2005!!
WTF? Anyone have any ideas?! The water itself was clean as a whistle and didn't smell at all like anything nasty (antifreeze, moldy)
I'm mystified...
Old 09-25-2008, 02:35 AM
mattd17's Avatar
mattd17
mattd17 is offline
this is a common problem with these trucks..... it is believed to be the A/C condensate drain being plugged up and the condensate then running into the floorboard rather than the tube it should. it is a real challenge trying to find it though to clean.
Old 09-25-2008, 03:38 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
Moonroof?
otherwise, I agree with Mattd17. The A/C condenser drain is likely clogged and you need to clean it out, or replace
Old 09-25-2008, 08:36 AM
Tom's Avatar
Tom
Tom is offline
Not to nitpick, but...
The A/C condensor is the unit mounted in front of your radiator, which cools hot R-134A coming out of the compressor...
You're thinking of the evaporator!
Old 09-25-2008, 03:34 PM
rival904's Avatar
rival904
rival904 is offline
I found water was getting into my truck from the 3rd brake light...
Old 09-25-2008, 04:19 PM
ggwash21's Avatar
ggwash21
ggwash21 is offline
Ditto on the 3rd brake light replaced gasket...
check your door seal you might not see or hear it but that might be causing it. that happened on my wifes 2005 taurus..... Also have you had your windshield replaced lately? i had a older ford that the dealer replaced windshield and did a poor job and leaked really bad...
just my .02
gary
BillC's Avatar
BillC
BillC is offline
There's a TSB on the brake light. Had mine replaced while under warranty.
Old 09-25-2008, 07:50 PM
FTE Trigger's Avatar
FTE Trigger
FTE Trigger is offline
Try running your A/C on Max for a while (enough to get the "water flowing") and run your hand under the heater core box in the pssnger side. See if you can feel any moisture.
Old 09-25-2008, 08:24 PM
snowmobilefan's Avatar
snowmobilefan
snowmobilefan is offline
I had this problem on my 2006 f 150. When I first noticed it when taking a 200 mile ride in a steady downpour, had ac on. 2 day's later I removed my rubber floor mat to clean and noticed my carpet was soaked, I removed sillplate and kick panel and pulled carpet back and found serious amount of water (passenger side) I thought my friend's water bottle had leaked there was so much water. 1 month later I discovered problem again and started testing, pulled carpet back and put ac on high and sure enough water started leaking in cab. I called the dealer and they said bring it in they knew what the problem was (there is a TSB on it) The problem is the tube on the evaporator sticks out straight thru the firewall and is about 1inch long, no downspout. They had my truck overnight. When I got my truck back I looked at the repair and noticed the elbow they installed cockeyed. I stuck my hand up there and touched it and it fell off. It was packed with red grease and impossible to install as it is the same ID as drain tube. I went to autozone and bought a bypass hose, cut to lenght and installed with a wire tie. End of problem. I am not at work but I saved the part # and can provide it when I get back to work (knee surgery tommorrow) So my Dealer knew the problem but between them and Ford they couldn't fix it right. Hope this helps.
Karl
Old 09-25-2008, 09:38 PM
tomdoggie's Avatar
tomdoggie
tomdoggie is offline
the third brake light puts water in the rear not in the front. Iagree on the evaporater drain.
Old 09-27-2008, 04:08 PM
2004 xlt 5.4's Avatar
2004 xlt 5.4
2004 xlt 5.4 is offline
does anyone know where to find it ???
Old 09-28-2008, 06:00 AM
snowmobilefan
Open hood, crawl or raise truck and look up you'll see drain right behind right cylinder head, valve cover area. It sticks out straight with no downspout. Water drains and runs along bottom of drain back into cab.
Karl
Old 09-28-2008, 12:09 PM
grandaddy's66
snowmobile, I think you have hit the motherlode for how to fix the evap tube - sounds just like my problem. GREAT explanation. Thanks
me love this forum long time!
Old 09-30-2008, 11:22 PM
ross385scj's Avatar
ross385scj
ross385scj is offline
What would cause water dripping on the Drivers Side under the dash. Got the water soaked carpet on the pasenger side but Driver????
Old 10-05-2008, 06:08 PM
tsd98's Avatar
tsd98
tsd98 is offline
Had the condensation in floorpan problem with my '05. Clean the drain on the passenger side firewall (engine side of cab) and go to you dealer to ask for the elbow that I purchased to fix this. The elbow is listed by Ford in a TSB for this very problem. Elbow costs less than $5.00, but is a huge pain in the @ss to get to. I had to remove the upstream oxyen sensor on mine to get the elbow on. Take a good falshlight and attempt ONLY when engine is completely cool! Good luck.
Quick Reply: serious amounts of water under the passenger carpet
