power adders
Old Sep 24, 2008 | 10:12 PM
traxx808's Avatar
traxx808
power adders
.......does anyone know if there is a good reliable company that has super chargers or turbo charger systems for the 1994 f150 5.0L automatic 4x2........and with these mods will any part of the fuel system need too be upgraded too handle the extra incoming air & will the ecm/ecu need too be modified also.........is there a company that the ecm/ecu can be sent too be modified for this upgrade..........will the transmission also need too be upgraded for this modification...........also what is more reliable too use on the street as well as the track.............will better gears also help with this transformation............where is the ecm/ecu located on these trucks........tried looking for it but could not find it????????..........any ideas on transmission upgrades & gears.............will under drive pulleys help with any of these upgrades.............does anyone know if these engine upgrades is 50 state legal.............help please............thanks.............
Old Sep 24, 2008 | 10:28 PM
9.ford.5's Avatar
9.ford.5
just a suggestion but try searching before you post to limit the q's u might get a faster answer
anyways if your going to do turbo im pretty sure you will have to upgrade the fuel injectors to 19lbs i think...i dont think any companies have caught onto a turbo kit yet if they did it would probly be stupid expensive and you might as well build it from junkyard parts. there might be a thread about a turbo on a 302 on here somewhere...look in the "supercharger, Turbocharger, Nitrous Oxide and Water/Methanol Injection" forum or the "Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)" forum might be something there .... there is a full write up of a turbo done to a 300 I6 on here but thats probably not gonna help much its in the inline 6 forum
Old Sep 26, 2008 | 07:39 PM
Jason Lewis's Avatar
Jason Lewis
Her's what you want !!!
I want this but don't have the $$$$$$$$$$
Vortech Engineering: Viewing product: 1987-1997 Ford F-Series Truck, SUV Supercharging Systems
Chefsteele
Jan 18, 2014 01:49 PM
Mtnplow
Sep 11, 2011 05:05 PM
Raymond
Mar 24, 2010 01:27 PM
Duh_Vinci
1983 - 2012 Ranger & B-Series
Apr 20, 2008 01:57 PM
JeepinRedNeck
23
May 31, 2005 05:54 AM
