Ranger Lift Question
Have a 92 Ranger Reg cab, came with 215/70/14's on. I want to put 31/10.5/15's on it with 15x8's.
To do this I know I need a lift. Would a 2" Daystar Leveling Kit for the front and 2" Rough Country blocks for the back work? This is just for looks, the truck just does daily driving.
If it isn't enough would I be able to fit 30/9.5/15's on it then with that lift?
Thanks.
your truck might already have them in there also i have noticed on some rangers they have a add a leaf already on there but they have it upside down so it doesn't raise the rear if you seperate the spring pack and flip it the right way you will get almost 2" of lift this spring will be on the bottom and you will see it is arching towards the ground that is the spring you flip over if you have any questions send me an email i have installed over 12 daystar leveling kits since i am a Daystar dealer and installed alot of them on rangers 4 and 2 wheel drive
idctd(No Email Addresses In Posts!)
