X codes & Bilsteins
Old Sep 24, 2008 | 03:15 PM
jhand124's Avatar
jhand124
X codes & Bilsteins
Got my X code front springs, bilsteins and new stabilizer links on today. I would have to say the ride is a little stiffer but not to much. The truck handles better, less body roll and no more clunk from the worn out links. The new springs raised the truck about 2", just a little bit lower in the front than the rear.
Thanks to you guys/gals for the advise on everything.
Old Sep 24, 2008 | 03:35 PM
03_PSD's Avatar
03_PSD
good deal, glad everything worked out!!
Old Sep 24, 2008 | 06:34 PM
Wieckster's Avatar
Wieckster
I put my code x front springs on acouple months ago and my front end is about 1 or 2 in. higher then the rear what can I do to fix that I dont like the look it looks like I have 5 yards of dirt in the bed. Any help would be great
Old Sep 24, 2008 | 06:46 PM
jhand124's Avatar
jhand124
I have a 350 which has larger blocks on the rear axle, you could put blocks from a 350 in. I also have newish springs in the rear too.
Old Sep 24, 2008 | 06:55 PM
PaysonPSD's Avatar
PaysonPSD
Jason,
Good going, another project out of the way.
Where did you get the x codes?
Which Bilsteins worked with the extra lift?
Old Sep 24, 2008 | 07:47 PM
Wieckster's Avatar
Wieckster
Where can I get a set of those larger blocks at?
Old Sep 24, 2008 | 07:50 PM
PaysonPSD's Avatar
PaysonPSD
I'd start with FTEPartsGuy. He's a site sponsor.
Old Sep 24, 2008 | 08:18 PM
jhand124's Avatar
jhand124
Originally Posted by PaysonPSD
Jason,
Through Direct Ford Parts (Silverstate Ford now)
The Yellow 4100 Bilsteins will work up to a 1-1/2" lift, I'm probably only 1" higher than stock, I raised it 2" from where my saggy worn out springs were.
Old Sep 24, 2008 | 09:58 PM
big poppa's Avatar
big poppa
Hey Jason, congrats on the new goodies. About that clunk, was it when you hit the brake you would hear it?? I had the same thing, i tightened up the swaybar bolts and the clunk is gone. Was that the clunk??
Old Sep 24, 2008 | 10:33 PM
jhand124's Avatar
jhand124
Mike
My clunk was related to side to side movement while hitting small bumps...so.a rocking motion with the suspension articulating at low speeds which is the only time you can get the rocking motion while loading and unloading the suspension.
If tighting them fixed it, that is a money saving fix. I have replaced mine at least 3 times along with the stabilizer bars once. There are places where you can get just the bushings, but that requires a large press to get the new bushing in, I will just pay the $30 for new links every 75K.
Old Sep 25, 2008 | 11:45 AM
harleydude03's Avatar
harleydude03
what are xcode springs
Old Sep 25, 2008 | 03:13 PM
big poppa's Avatar
big poppa
Got yaa Jhand124. I do notice the one stabilizer end bushing is starting to wear out, might be switching mine out soon, thanks. Hey, what happen to your PM link??
Old Sep 25, 2008 | 08:19 PM
jhand124's Avatar
jhand124
I was having trouble joining the MN chapter and so I asked for some help and everything got messed up. I couldn't log on to the forum, now I can but I lost my supporter badge and am having to deal with ads.
Old Sep 25, 2008 | 08:20 PM
jhand124's Avatar
jhand124
They are OEM springs that come on the plow package.
Old Sep 25, 2008 | 08:32 PM
big poppa's Avatar
big poppa
Well i,m glad that everything is ok now but you got to go in to your messages and clean out your pm,s so i can send you a PM, tried but couldn't!!!
