Sqeaky center shaft support
Old Sep 24, 2008 | 01:12 PM
SUPERJADE77's Avatar
SUPERJADE77
I've got a squeak that is driving me nuts on the center driveshaft support on my 77 supercab. Anything I can do? Or just replace it. No zirk fitting. Is this an urgent thing?
Old Sep 24, 2008 | 01:16 PM
Jolly Green's Avatar
Jolly Green
Sounds like you have a bad carrier bearing. My standard cab '79 does not have a carrier, but I've had other trucks with them and have had to replace this. Easy fix. Might as well replace the u-joints while you're at it since you'll have to drop the shaft.
Old Sep 24, 2008 | 01:23 PM
SUPERJADE77
Thanks. That's kind of what I figured. And I figured I would do the joints while I had it apart. Is this urgent though. It just started doing this and I've been driving it pretty easy. Nothin else to drive right now. My 79 is full of yard debris at the moment.
Old Sep 24, 2008 | 01:32 PM
Jolly Green
Well, if the Ford set up is like the others I've replaced (Nissan and a buddy's chebby) then you probably have some time. It's going to annoy you and get louder as it wears, and you won't have the support you should have on the shaft--but then, you're going to replace the u-joints anyway. But, don't let it go to long-my friend ended up "welding" his to the drive shaft because he let it go too long with the bearing shot. Even a jaw-puller couldn't help. We ended up cutting it off.
