Wiring Schematic
Old Sep 24, 2008 | 09:55 AM
CGD's Avatar
CGD
Question Wiring Schematic
I am looking for a wiring schematic for the parking brake on a 05 F250.
Thank you for any help in advance.
Old Sep 24, 2008 | 10:18 AM
tazo's Avatar
tazo
https://www.motorcraftservice.com/pu...20/S5OMAIN.HTM
This might be what you are looking for.
Old Sep 24, 2008 | 12:06 PM
CGD's Avatar
CGD
that's what I was looking for thank you. I am putting in a switch so you can use the high idle mod with out having to apply the parking brake.
Old Sep 24, 2008 | 10:30 PM
CGD's Avatar
CGD
all setup! all you have to do is take an on/off switch and wire the on side to ground. run a wire from the off side to the green wire on the parking brake indicator. when the switch is hit it applies ground and turns your parking brake indicator light on without having to apply the parking brake. now hit your high idle switch and "presto" high idle is on without ever applying the parking brake.
Old Sep 26, 2008 | 05:15 AM
PupnDuck's Avatar
PupnDuck
Assuming that you're using either an upfitter switch or some other switch to activate the high idle feature, why not use that switch to activate a small 12 volt relay with 2 sets of contacts. Use one set to apply power to the high idle circuit and the other set to apply ground to the parking brake circuit. You can tuck the relay up behind the fuse panel an tie wrap it in place.
Now you only need to use one switch to activate high idle.
Old Sep 26, 2008 | 10:27 AM
06F250XLTFX4's Avatar
06F250XLTFX4
That is a really good idea PupnDuck. I think i am going to wire High Idle switch that way.
Old Sep 26, 2008 | 01:11 PM
skoveng's Avatar
skoveng
tazo, do you know the motocraft link for the '03's. I'd like to try the same.
thanks! Steve
Old Sep 26, 2008 | 06:54 PM
juneau76's Avatar
juneau76
Here it is:
https://www.motorcraftservice.com/pu...20/S3OMAIN.HTM
juneau76's Avatar
juneau76
Who knows, you may want this some day, too:
On Board Diagnostics 6.0L Diesel
Old Sep 29, 2008 | 07:06 AM
skoveng's Avatar
skoveng
juneau76, Thanks for the info! Steve
Old Sep 29, 2008 | 10:57 AM
tazo's Avatar
tazo
https://www.ford-trucks.com/forums/7...p-manuals.html
This is where I got the info from. Thank you ozx3+1
Old Sep 29, 2008 | 04:59 PM
EOD Guy's Avatar
EOD Guy
Or you could buy a DPDT (Dual Pole Dual Throw) toggle or push button switch and have kust one moving part.
