Sponsored by: Real Truck
Which transmission do I have?
Old Sep 24, 2008 | 06:58 AM
michaeloac's Avatar
michaeloac
I recently bought an 03 250 with a 5.4 4x4, it did not have any paperwork with it. I received a build sheet and it lists the tranny with this code-1C3P7000BC, does this tell you what type it is-4spd, 5spd, does it have an exterior filter that needs to be changed? Once again thanks in advance for any info, Mike
Old Sep 24, 2008 | 07:20 AM
PowerStrokeHD's Avatar
PowerStrokeHD
The transmission would be the 4R100 (4-spd) and there should be no external filter installed, unless it was done at some point after it left the factory...
Old Sep 24, 2008 | 08:39 AM
michaeloac's Avatar
michaeloac
Thanks for the info, I am getting the fluid changed today and am opting to let the pennzoil lube people do it, they use the same machine as the ford dealer at almost half the price
Old Sep 24, 2008 | 09:25 AM
PowerStrokeHD
The quick lube places may be cheaper than the dealer, but you really have to watch them. Many will use a generic ATF that they will tell you meets Ford specs or tell you that they have added a additive that makes it meet Ford specs...
