i belive that it should, does your truck already have duel tanks or just single? im pretty sure that if a stock tank fits in the rear location then an bronco tank should, acualy come to think of it, if it fits on a bronco it should fit on a short bed truck.
yes you can put a bronco tank (33 gal) in place of your rear tank. however you will lose your spare tire spot. the bronco tank is much more cubish than the stock tank. you will have to get longer bolts b/c the bronco tank is a good deal taller.
i love the bronco tank mod. its so much easier pulling a trailer not to have to pull in a gas station every couple hundred miles. i live in the metro atlanta area and i can go to our lake house towing a trailer (in alabama) and back without stopping for diesel where as my dad has to pull in on the way over so he doesnt get too empty!
