Sponsored by: Real Truck
Rumble from right front
Old Sep 23, 2008 | 05:22 PM
nut1605's Avatar
nut1605
I have a 2007 F-350 4x4 and whenever I make a left hand turn under acceleration, the right front seems to make a real low "rumble", almost like something is dragging. I have tried locking/unlocking hubs, engaging, disengaging 4 wheel drive, everything I can think of, and it still does it. I'm at about 30,000 miles, so I am thinking of taking it in before the warranty runs out. I am just not too sure what to check and what all the terminology is since this is my first 4 wheel drive. Thanks in advance!
Old Sep 23, 2008 | 05:27 PM
ironmine's Avatar
ironmine
Bad wheel bearing/hub assy? If you can, jack up the corner of the truck, and spin the wheel by hand .... see if you hear it or feel it .... roughness as it spins. Grab the tire along its circumference, and try to muscle it around .... feeling for a little looseness.
Good luck...glad you're under warranty.
Old Sep 25, 2008 | 04:08 PM
Tazzmann's Avatar
Tazzmann
Hey Nut if you do take it in please post back with what the problem was. I'm have the same problem just left front wheel. and after replacing most of the front end (both wheel bearing assy's included) the noise/feeling is still there and getting worse. So post back what happens!!
