So while ive got the trans out of the truck, is there anything else i should replace, besides the slave and the clutch?
Also im doing all the u-joints too as it needs them...
Or anything to do while under there that can boost some performance?
Change the tranny and T-case fluid. . .maybe change out the tranny mount for a new one, especially if it's old and covered in crap. . .now would also be a good time to inspect your rear engine oil seal and replace if necessary.
Pilot bushin, throwout bearing check the clutch fork for wear, check all the yokes too. Also make sure ya get a new slave cylinder line. Rear main for sure, also check al the seals on the tranny and t case to see if theyre leakin.
lucky you...
Internal slave... I wish i could meet the ford designer that came up with that brillant idea...
I would kick his **** so hard he would fly back in time and change that damn design...
Im not sure but my 85 wont go over 10 in granny in 2hi and thats revin it up alot. If I remember right your first gear should get ya to about 20 right?
wow i was way off... Dont know where i got that number... The zf i got in my truck the 1st gear ratio is 5.72... with the 4.10 gears, on stock tires IT CREEPS... But now its good since im still rolling 4.10 gears but 37" tires...
