1978 - 1996 Big Bronco
front springs
Old Sep 23, 2008 | 10:12 AM
bertha66's Avatar
bertha66
front springs
My front end is sagging, it is a 80 Bronco with a 460 engine. If I replace the front springs with the stock springs, will it just sag again? or will a set of springs from a F250 with a 460 fit and hold it up better?
Old Sep 23, 2008 | 10:16 AM
alxsnmr's Avatar
alxsnmr
The front springs from an F250 or F350 2wd have been used on half-tons to level the front end stance. I do not see a reason why you could not to help out on your bronco.
Old Sep 23, 2008 | 12:20 PM
bertha66's Avatar
bertha66
Thanks, I will look into picking up a set of F250 springs.
Old Sep 24, 2008 | 09:12 AM
alxsnmr's Avatar
alxsnmr
There was someone in the trucks section that did the 2wd F250 front spring swap onto an F150. May do a search and see if you can find his posting.
