Sponsored by: Real Truck
Leveling Kit
Old Sep 23, 2008 | 08:44 AM
onuredneck707's Avatar
onuredneck707
Leveling Kit
Has anyone out there put a leveling kit on their truck? I have an '05 PSD, CC, SB, SRW and was wondering what the max tire size is with just a leveling kit. Most of them claim the max size is around 37" with the 2.5" leveling kit, but does this mean that is what will fit in the wheel well? Will they still rub when you turn?
Thanks for the help.
Old Sep 23, 2008 | 10:27 AM
riggz's Avatar
riggz
Search "leveling kit" in the super duty forum and you will find hundreds of threads on this. I would think 37 might rub at full turn if the suspension is not on level ground. 35"s would be a safer bet.
Old Sep 23, 2008 | 10:55 AM
UGA33's Avatar
UGA33
With my setup, i am almost positive i could run 37's and not scrub too much or at all. I ran my current tires two days before i installed the kit and had no issues lock to lock with scrubbing It all depends on wheel sizes to. I guy i know who has an 08 w/ the 20in wheels and he is running 37's with a 2.5in leveling kit. It looks pretty good in my opinion. It definatley feels the wheel wells up. It will all depend on your wheel deminsions
Kep4's Avatar
Kep4
Jäger
Mine has Bilstein 2.25" leveling coils and Bilstein 5100HD shocks running 35-12.50x17 Toyo M/T's on 17x9 Raceline wheels with a 5.00" backset.
The front tires just clear at full lock at full suspension compression. I've wheeled it hard and never had tire contact. I had to install a Donohoe (now Icon) adjustable panhard bar to properly center the front axle and that helped with clearance issues.
There is no way 37" tires up front would clear on my truck.
Old Sep 23, 2008 | 07:39 PM
sarnott140's Avatar
sarnott140
where did you get your kit and panhard bar?? I'm thinking of doing that to my truck Do you notice the extra suspension travel?
Old Sep 24, 2008 | 08:35 AM
Kep4's Avatar
Kep4
Jäger
I bought the leveleing coils and shocks through Desolate Off-Road in Southern California, they also installed it for me.
The panhard bar was purchased through Kartek Off Road in Corona, CA. Kartek Off Road - Where the Off-Road is On!
I definitely noticed the improved suspension travel! Far less bottoming out and a much smoother ride both on and off road. Eliminated the Death Wobble as well.
It's made a huge difference in the handling and ride of my truck and I highly recommend it.
Old Sep 24, 2008 | 09:16 AM
onuredneck707
Thanks a lot for the help guys! I appreciate it. Has anyone used any of Summit Racing's leveling kits?
Old Sep 24, 2008 | 10:16 AM
GregsSD's Avatar
GregsSD
The first year that I had my truck I added the Daystar 2-3/4" spacers and some longer Rancho shocks. My truck drove fine without having to realign it or anything!!!
So for a cheap levelling kit I would recommend it. The only reason I took it off was to go to a 5" lift.
Old Sep 24, 2008 | 03:39 PM
UGA33's Avatar
UGA33
^^^^^^^^X2. Have the same setup, and it cost me less than $300 bucks.
