2-3inch body lift help
i am lookin for either a 2 or 3 inch body lift for my 1990 f150 4x4 300 I6. Can anyone help me find one(i found one but for 75.00 but it says it wont work with my engine) and how easy or hard it is to install.
can anyone give me a brand/price/or any help at all thanks
BRUNO
:-X11
BRUNO
:-X11
Well I have a 3" body lift on my 1999 F-150. I love it, I have a slight advantage that one of my best friends is a Ford mechanic at a dealership, and he helped me put it on, which took about 4 hours to do it correctly. If you do heavy off-roading suspension lift is the way to go. But, if you just want something to look good, a body lift is safe as long as you have somebody qualified to install it. I have a Performance Accesories body lift which I bought from JC Whitney for $150.00, and it was a great kit and had easy to follow instructions. I just figured I would say something positive about the body lift,k because mine has worked out great. THANKS
Bruno, I have a 94 2WD 300 I6 with a 2" body lift. When I got my body lift they told me that the reason the kit wasn't avaliable for the 300 I6 was because they can't offer a molded lower radiator hose. To correct that I just got a 2" ( I think thats the size) standard hose. It is a tight fit, buts it's held up for about three years now. I hope this helps.
Kevin
Kevin
