Offroad & 4x4
Tow hooks
Old Mar 21, 2002 | 10:38 AM
KJKozak2's Avatar
KJKozak2
Tow hooks
Greetings.
Has anyone used the tow hooks that JCW sells? The ones that bolt on to the frame and have a retainer clip to keep the rope or strap from unhooking.
I can get a set at the local farming store pretty cheap, and was wondering if they are strong enough. Has anyone ever seen these break or fail in any way?
Thanks!
Kevin K.
Old Mar 21, 2002 | 02:27 PM
orange peel's Avatar
orange peel
Tow hooks
i bought some exactly like that from advanced auto parts, had to drill one hole on each side and there was one hole already in the frame that i bolted them to. theyre really strong, ive been yanked out by one, out of a mud hole with out any engine power from me, the guy had to really YANK me out.
Old Mar 21, 2002 | 02:42 PM
KJKozak2's Avatar
KJKozak2
Tow hooks
Thanks ORANGE, That's what I wanted to know. Hopefully, mine will be used more for pulling that being pulled.
Kevin K.
Old Mar 21, 2002 | 05:45 PM
canadianfordman's Avatar
canadianfordman
Tow hooks
I bought some warn hooks rated at 10,000#'s each. They are on the truck with one bolt and they have been great. Best Part, only $10 each Canadian.
Old Mar 21, 2002 | 08:19 PM
fordmaniac21's Avatar
fordmaniac21
Tow hooks
i have walmart tow hoks on my 4x4 and wheel it at least 3-4 times a month and have had my truck pulled out more times than i have wanted to utilizing the tow hooks. they wok and still hold up to everything. my only problem is the little retaining clips breaking from bottoming out on rocks or DEEP mud. so i took em off.
'75 F-100 4x4, 4" lift
16x38.5x15 super swamper TSL
mini-spooled 9" rear end
390 w/ cam,headers,
and 4 barrell edelbrock
TRIED TRUE and FORD BLUE
Old Mar 22, 2002 | 05:39 AM
rabidranger's Avatar
rabidranger
Tow hooks
I have never seen a tow hook break, but I have seen the bolts that hold them down break. If the hooks don't come with bolts use grade 5. I am gonna catch a ton of flak, but grade 8's are too brittle. They are stronger, but the 5's won't shear as easily. Just commenting from experience.
Old Mar 22, 2002 | 08:25 AM
KJKozak2's Avatar
KJKozak2
Tow hooks
Thanks everyone! It's god to know that these work and are strong enough. For the price, ya can't go wrong.
My only other concern is weather or not the really wide two straps will fit in the hook. The ends are usually folded over at the loop and appear to fit, but I haven't actually tried it. Anyone have problems there?
Thanks again!
Kevin K.
Old Mar 22, 2002 | 08:29 AM
AZ4x4f150's Avatar
AZ4x4f150
Tow hooks
The hooks are good the spring retaining clips can be a pain.
as for the right bolts to use a grade 5 will bend alittle before it breaks.
a grade 8 is alittle stronger but yes more brittle due to hardening
now when it comes to a bolt it is measured by tensile strength which boils down to clamping force and bolt stretch. now shear strength is roughly 60% of the tensile strength that is a force from the side of the bolt until it breaks.
Old Mar 22, 2002 | 06:46 PM
The Man's Avatar
The Man
Tow hooks
If i were you i would go to AutoZone they have Black ones that come with Grade 5 hardware and only cost 7.99us thats 2.00 cheaper than the ones from Wal-Mart that come with only Grade 2 hardware.
Later
Tom B
Old Mar 24, 2002 | 09:42 AM
cat f100's Avatar
cat f100
Tow hooks
KJKozak2
Wisconsin Chapter
Sep 27, 2003 09:24 AM
KevVer
Jul 25, 2003 02:51 PM
KJKozak2
Aug 12, 2002 03:28 PM
KJKozak2
Offroad & 4x4
32
Aug 2, 2002 02:06 AM
captainkev
Apr 16, 2001 01:16 PM
