Offroad & 4x4
solid front axle on bronco
Old Feb 19, 2002 | 06:44 PM
orange peel's Avatar
orange peel
i have thought about gettin spring hangers off an f-350 or 250 and welding them on my frame but im not sure how well that would work, thanks for the web site.
Old Mar 13, 2002 | 12:44 AM
Mud Hogg's Avatar
Mud Hogg
Post solid front axle on bronco
[updated:LAST EDITED ON 13-Mar-02 AT 01:49 AM (EST)]>If I were to get the 6 inch suspension superlift with that
>superrunner steering what special tools would I need to
>install it myself? cause a shop quoted me at $1152 to
>install and they said that was equal to 18 hours of work.
>That is a long way from here. It just shows how this country
>loves fords.
Hey I installed the Super runner kit on my 82 F150. It takes a few simple tools and about a days worth of work with a little help. I'm also removing the TTB and installing a strait axle out of a 79. If you want some tips on either I'd be glad to help with any info I have. Also opt for the add-a-leaf in the rear due to the factory rear bump stop blocks. The simple tools are wrenches,sockets, pitman arm puller, drill, ball joint seperator, a grinder, and you need to replace the axle piviot bushings while it's apart.
Mud Hogg.
Old Mar 13, 2002 | 10:30 PM
mudinford's Avatar
mudinford
I got the Fabritech kit in my garage now. got the 10" and got the extras all on my own.....lots cheeper. i have Fabritech's home page.
http://www.setstr8.com/ my truck will be as tall as the Bronco on the front page. Same setup i got. You say that its expensive...yes....but i have seen the quality first hand and its bar none! boxed radius arms....that are bent to allow larger tires...and even longer than the stock '78 Bronco's (wich are already long!). Can you say flex? they give you ALLLL the hardware to install. Poly bushings and detailed instructions....the only beef i have with them is that their cust service is rotten. I had a dual shock kit made and it didnt get included. I have been tring to get it for almost a year now.....you would fig since i paid ...i would have it.....but i hope they will come around. but i am just waiting on my engine to get finshed so i can put it on. will make me happy. when i get it up and running ill post some pics. my two....
Dan "Mudinford" MacDonald
'86 Ford F-150 4x4 w/ a spooled mono Dana 44/a spooled 9" running 38" TSL. 300ci, Clifford Intake and Headders, .05" Milled Head with SBC valves, port work
500 CFM Edelbrock, Clif. 290* cam with Rhoads lifters, .040" TRW Pist w/ Moly rings.
Future plans: A draw through Twin(or big single) Turbo setup (to help with the upper end)
Old Mar 25, 2002 | 12:00 AM
79F2504x4's Avatar
79F2504x4
Old Mar 31, 2002 | 12:38 AM
mwc4275's Avatar
mwc4275
I just got done helping out installing a solid axle in an 86' bronco. It's pretty easy to do, and you don't need those stupid *** expensive kits. If you have the everything with the solid axle, it's not that hard. The hardest part is getting your radius arms located correctly. You have to change the pitman arm, and you can't run the stock steering stabalizer shock.
Old Mar 31, 2002 | 02:20 AM
mudinford's Avatar
mudinford
Well let me add that its not a simple bolt up job like you are implying(sp?). You have lots of problems to figure out to get the axle to work if you stay with the coil springs...and you said you used radius arms...so i assume you did. Let me ask you how you solved some of the problems so as to help thoes that are lookin into this conversion.
A '86 model has a low engine cross member to work with the TTB front end. If you just put a solid axle under there, it (the pumkin) will hit the crossmember. Did you modify this or run a lift?
Second...with a coil sprung axle, you have to run a panhard bar. Where did you find the room to mout this bracket? the frame is not flush where you need to mount it. if you move it fwd, you interfear with the steering. Move it back, it simply wont work (crossmember interfears). you can use the engine cross member to mount a bracket....but you would have to find a shorter panhard bar..BUT there is that clearence issue again....and i might add it woudl have to be adjustable as well.
Next, the 86 spring bucktet will not work with the mono springs. they are narrower springs than the '86's. you would have to swap out the spring buckets.
Other than that.....its pretty straight fwd. I just dont want anyone going out and buying an axle and just tring to stick it under the truck hoping it will magicly work....it wont....some of us can modify things to make it work...some cant....just have to know your limits...i am here telling what i encountered when i tried to get the dana 44 mono to fit. Thought it would be just as easy to buy a kit...rather second guessing my custom fab job i would almost certanly have to perform to make the swap work.
Just my 2 cents......
