On my 05 the driver side battery is no longer holding a charge the passenger side does. I was always told to replace both of them at the same time do I really have to? can I just buy one now and the other one at a later date? money it tight.
Thanks
Thanks
If you just replace one, in short order it will be no better than the one its connected to.
If you don't replace both your just wasting you money because the old battery will kill the new battery. The old battery will draw off the new battery.
Also low voltage will kill your starter I haven't bought a starter for a 6.0 but I imagine they are not cheap.
What he said ^^^^^^
some things can be left , some things need to be done. I know it can suck being tight on cash, but replacing 1 battery will just end up coming back to haunt you.
Replace both, and clean the terminals real good, and get the alt. tested. spend a few bucks, and prevent a serious failure(s).
Enjoy eating mac&cheese the next 2 weeks, its worth it.
Though I agree with all of the above, last winter Mine cranked very hard. I took both batteries out and brought them to my local CAP. They tested both batteries and under a load the driver battery dropped to 9.5 volts while my passenger dropped to 10.6 volts. Guy there said just do the one battery. I put an Exide in and its coming up on one year and no problems.. but then again its not winter yet. I did have 3 days it went town to 34 degrees already and it sounded perfect. Just my 02 cents.
I'd suggest spending a few minutes in the electrical forum... You'll soon get to spend twice the money to get two new batteries to replace the two you now have. Hope your alternator makes it thru this...
It's pretty simple: they are tied together + to + and - to -, they will continually try to equalize, that's just the way electrons like it -- unfortunately, batteries do not like it.
If you are short on funds, I would not replace just one battery. You will end up having to replace the old one, or even both the old and new one a lot sooner then you would have to..
While mismatching batteries can kill both, I do not think they can kill an alternator, unless ford uses some severally underrated alternator that can just barely power the truck
But yeah, say one of your batteries just died, and you replace just that one. While your other battery isn't quite dead yet, some of the cells may be failing and it may only want to be at around 11.9 volts. Now when you turn your truck off, this dying battery is going to want to try to stay at 11.9 volts, while the good battery that is at 12.6 volts is going to try to send power to the dying battery to get it to match its voltage. So during the night the good battery is going to drop below 12.6 volts, and your going to start boiling the remaining good cells in the dying battery, quickening its death. Car/Truck batteries do not like being under 12.6 volts open circuit. They deteriorate very quick below that voltage
Thanks
Drive to Advance Auto Parts, or similar Auto Parts store and ask them to load test both batteries. IF both (meaning the new and old good one) are within 5% of each other as far as CCA etc, you should be fine.
Make sure to have them load test the NEW battery before you install it. I had 2 batteries in my truck with 11/2007 stickers on them, one went bad. After they replaced just the bad one I again started having slow starts within days and believe it not the NEW battery was the low one. I took it back and they tested it and it had a bad cell. I asked them to load test the replacement AND my other one dated from 11/007, and specs were basically identical. So far everything is perfect and checking each battery separately a few weeks later and both have the same static voltage (unhooked of course).
While the advice to replace both OLD batteries at once is great advice there are always exceptions, especially if they are less than one year old.
I have confirmed this with a Ford tech. If your old battery tests fine under load then it is ok to replace just one battery. There is no possible was a battery can kill an alternator. An alternator charges the battery. If a batter has a bad cell or cells then it simply will not accept a charge in those batteries. Simple logic. An alternator can hpwever kill a battery by overcharging and causing a battery to explode. That would be the regualtor that causes this and is a whole other subject. In short yes its ok to change one battery and not have to worry about it effecting anything else.
A bad battery can cause an alternator to fail, as the alternator will overwork itself by constantly trying to give a charge to a battery that will not accept it.
If the old battery load tests within 5% of a new one, for the sake of saving money you'll be ok for awhile. Just remember its had the same amount of use as the one that failed.
I always just replace the one that is bad. If that battery is good it can't kill anything, and if it was to kill the new battery, that batter being new is under warranty.
