Sponsored by: Auxito
Replacing Thermostat
Old Sep 21, 2008 | 10:56 PM
astone's Avatar
astone
Hey,
I decided to replace my thermostat while changing the coolant at 100,000 km. I did some reading after replacing it (I should have done that first) and noticed one one of the threads said to take note of the position of the bypass an put the new one at the same position. I did not do this and just put the new thermostat in. I am assuming the bypass is the little hole with the small bobbly thing in it. Does it really matter? If so what location should I have put it in?
Thanks
03 Screw 4x4 4.6l.
Old Sep 22, 2008 | 06:24 AM
projectSHO89's Avatar
projectSHO89
The bleeder port should be at the 12 o'clock position.
It is there to allow air to bleed from the system when the 'stat has not yet opened.
Steve
Old Sep 22, 2008 | 03:12 PM
astone's Avatar
astone
Thanks Steve
Is it worth taking apart to check the location, does it really make a difference? I think I put it toward the front of the truck.
By 12 o'clock is that facing the vehicle from the front, meaning that the bypass would be toward the firewall?
Thanks again.
Old Sep 22, 2008 | 06:08 PM
projectSHO89
12 o'clock means straight up.
