everyone except this^^^^^ guy because he plows sheep at the edges of cliffs
seriously though, they will fit fine as long as they aren't some wide knobby tire like a 35x14.50 or wider, then you may have some rubbing issues besides the regular radius arm rubbing.
35's would probably fit in the back but the front would rub for sure,the 33's do when wheels are cranked. And i dont want the tires to look stuffed in there.what to do?
and where do they rub? bet its on the radius arms. 3 answers to this problem. buy some extended radius arms with the tire reliefs, get rims with more offset, or adjust your steering stops so you can't turn as far.
oh, or option 4. put the 35's on and stop whining like a little girl with pigtails because going with a taller lift won't stop the rubbing if it is on the radius arms. and if it is rubbing somewhere else(unpossimabull with a 4'' and 33's) you have something else fubared that needs attention.
