Sponsored by: Kumho
Thumping Noise
Old Sep 21, 2008 | 11:00 AM
NV250's Avatar
NV250
Thumping Noise
For the last month or so, my F-250 v10 4x4 with 8" lift has been making this terrible thumping noise when I drive over any kind of bump or make a hard turn. The noise is coming from right under my feet .It has been getting continually worse, however, I was able to trace part of the sound to the steering box, which does thump and groan when I turn the wheels. However, I do not see how this can be the only problem since my truck thumps when I hit a bump. It feels much more severe than just A steering box. Anyway, I'll try replacing the box first, then see what happens. I know it is not the leaf springs or cv joints. Possibly a bad joint somewhere else? Has anyone had a similar experience?
Old Sep 21, 2008 | 12:07 PM
rebelyell618's Avatar
rebelyell618
i would look at the sway bar end links, that was where my thump came from when i turn the wheel.
Old Sep 23, 2008 | 09:10 AM
NV250's Avatar
NV250
Thanks for the reply. After working on my truck, I was able to trace the problem to the steering box. I think that is it.
Old Sep 23, 2008 | 11:16 AM
ynevada's Avatar
ynevada
so a new box fixed it?
i was going to suggest the body mount. ive seen several truck where the mount just below the drivers feet gets loose. and lets the cab bounce slightly.
also a bad shock. sometimes they'll come apart internally, and make all sorts of noises...
Old Sep 23, 2008 | 02:59 PM
NV250's Avatar
NV250
Really? I'll be sure to check that out. I actually have not replaced the box yet, but it is definately bad. How would you replace a body mount?
Old Sep 23, 2008 | 05:30 PM
ynevada's Avatar
ynevada
might be that the bolt has just come loose.
Old Sep 23, 2008 | 11:11 PM
NV250's Avatar
NV250
I guess I was wrong. I brought the truck into the shop and it turns out it was a stripped bolt which holds the traction bar, so the bar was not being held in place. That was a huge relief. I guess the sound was only traveling into the steering box.
Old Sep 24, 2008 | 10:28 AM
ynevada's Avatar
ynevada
glad you got it figured out.
