Sponsored by: Real Truck
Can I?
Old Sep 21, 2008 | 12:28 AM
V10 Family Truckster's Avatar
Can I?
Can I swap out the 16" rims on my 2000 F250 CC SB 2wd for the 2008 20" factory 8-spoke rims? Will they even fit on a 2wd & any other issues I'd be facing with this swap.
Old Sep 21, 2008 | 03:38 AM
Monsta's Avatar
Monsta
Sit. Stay.
You need 2" (or 1.5") wheel adapters/spacers to make it work. Look at my gallery to see what they look like...well...the wheels, not the spacers. I didn't get a picture of them.
You need HUB-centric spacers. I got mine from Wheeladapter.com Wheel Adapter Wheel Spacer Used Wheels New Rims Tires Gage Guage Gauge Wheal Wheals Adaptor wheelspacer wheelspacers stud studs billet bolt pattern custom parts part titanium fabrication aluminum rims rim part parts titanium coating
Old Sep 21, 2008 | 10:36 AM
Hey Monsta, thanks for the site, I've heard some guys say to avoid spacers, but my truck isn't used for off road, just drags a #8000 TT in the summer and runnin around, have you had any problems? Did you have to do any recalib? I understand that if the final outside tire diam. is the same it should be fine. How much did those spacers run ya? Rims look sharp, Thanks again!
Old Sep 21, 2008 | 12:15 PM
rollerstud98's Avatar
rollerstud98
If the spacers are steel and hub centric they shouldn't be a problem, duallies run spacers on the fronts fromt he factor
Old Sep 21, 2008 | 02:31 PM
Monsta's Avatar
Monsta
Sit. Stay.
I have no issues with the spacers. Due to the width & backspacing of the new rim, it is basically in the same place as the old rim. It doesn't stick out and the inside of the wheel is in the same position as the old stock wheel. So I shouldn't have any bearing issues.
I used my Superchip tuner to recalibrate for tire size and also for the 4.30 gears I installed. I used 285/55-20's. The tires aren't too much larger, height wise, than stock.
