Sponsored by: Auxito
1997 F150, IT STARTED
Old Jan 5, 2001 | 09:27 AM
codym's Avatar
codym
I have been havoing problems with getting my truck started. It is a 1997 f150 ext. cab, 4.6, 178,000. It keeps blowing the starter relay fuse when I turn the key to the start position. I turned the key to run, and jumped across the solenoid, and the truck started just fine. Does any one know what I should do next? Every day I can't drive it, is a day my friends with chevrolets pick on me. Please help so I can once again defend my FORD.............
Old Jan 6, 2001 | 08:11 PM
RAD's Avatar
RAD
Check your positve starter wire from the sol. down to the starter to make sure that there is no bare wire touching the frame and grounding it out. This will cause your fuse every time you turn the truck to the actual start position.
1997 ORP 4X4 Supercab
Centerline Neptune Wheels
285/75R16 Bridgestone Duellers
Westin Step Bars
Extang Tonneau
Diablosport Chip
JVC Kameleon Head Unit/ Rockford 10"Subs
K&N FIPK Gen. II
Old Jan 6, 2001 | 08:49 PM
mefsh's Avatar
mefsh
OK when you jumped the solonoid you went through your hot wire to your starter so it can not be that. I would take a look at your ignition switch. Probably in the wiring from sw to solonoid or the switch it self.
Old Jan 6, 2001 | 08:53 PM
mefsh's Avatar
mefsh
Have you tried a new solonoid?
Old Jan 7, 2001 | 10:18 AM
codym's Avatar
codym
I did put a new solenoid on the truck... So, I will trace the wiring from the switch to the solenoid. If it is bad, maybe a new ignition switch, I'll let you know. Thanks immensely for the help!
Old Jan 7, 2001 | 10:59 AM
nitro94's Avatar
nitro94
If I understand your last post you now have it starting but are not sure if the problem is going to return? If you need more info ask, I have wiring diagrams.
2000 XLT Flare Supercab Sport 5.4-Auto-355LS-Tow pkg-Bedrug-Xtang Tonneau
Old Jan 7, 2001 | 11:44 AM
mefsh's Avatar
mefsh
Blaster696969
May 14, 2012 05:32 PM
1997 F-150
Southern Region
Feb 9, 2011 11:28 AM
Nutsy13820
Oct 10, 2007 07:06 AM
Bliath
1997 - 2003 F150
Jul 22, 2005 11:37 AM
envsol
1997 - 2003 F150
Feb 25, 2004 11:58 AM
