Sponsored by: Auxito
brake troubles i think
Old Sep 19, 2008 | 06:28 PM
firefighter1416's Avatar
firefighter1416
hey guys i'm having some brake problems, it appears they are dragging a bit, also when i travel at a high rate of speed and need to stop suddenly they just don;'t seem to grab right and kind of make a grinding sound, the pads are fine rotors are fine. thanks for you help
Old Sep 21, 2008 | 05:35 PM
KingRanchMan02's Avatar
KingRanchMan02
Check the pins that the calipers slide on to insure that there is no binding. No problem found there, then replace the rubber brake hoses from the body to the caliper. Good luck!
Old Sep 21, 2008 | 06:22 PM
Dialtone's Avatar
Dialtone
When was the last time you checked the rear shoes?
They could be source of the noise and reduced stopping effect
Old Sep 21, 2008 | 08:10 PM
firefighter1416
my back pads are also new the only thing not new back there is the rotors but they appear to be fine, i might try the new hoses on the front with almost 200000 miles they might be starting to colapse
BigBlockF350
56
Apr 2, 2013 05:55 PM
berry1234
17
Aug 11, 2008 04:42 PM
greenterror
Jan 14, 2008 07:53 AM
greenterror
Mar 20, 2007 08:30 AM
sleepyhead416
Feb 19, 2007 07:07 PM
