Offroad & 4x4
IS THIS NORMAL
Old May 23, 2002 | 12:25 PM
DUKHNTR4LFE's Avatar
DUKHNTR4LFE
IS THIS NORMAL
Ok well i wanted to test my 4wheel drive to make sure that it was working right for this weekend, and i havent used it since last duck season. so i lock my hubs put it in 4hi and everything seems to be wokring fine tell i go to turn around. my truck started to skip and hop. it does this when i turn both ways and my tired are not rubbing on ne thing is that normal becuase i dont remember that happening before. also i hear a slight pinging noise only when i excelerate do u know what could be causeing that
ne info will help
dukhntr
Old May 23, 2002 | 12:47 PM
thomasr's Avatar
thomasr
IS THIS NORMAL
If you were on dry, solid pavement, the skipping and hopping is probably normal. Since you have some much more traction, the front wheels are kind of fighting the back wheels on which direction everything wants to go. It's a good thing to engsge 4WD every once in a while but it's probably best to do it off-road or in loose soil to avoid all the unnecessary stress. The pinging...I dunno on that one...what kind of ping? Valve ping? Mechnaical ping?
REX
Old May 23, 2002 | 12:49 PM
RichF350V10's Avatar
RichF350V10
IS THIS NORMAL
You didn't say if you were on a hard packed surface or sand or dirt.
The wheels travel at different speeds during tight turns. The 4WD on Ford superduty trucks has no differential between the front and rear axles. So, on hard surfaces the only way to compensate for the different distances traveled by the axles is for the wheels to skip - slip. On soft dirt or sand track you don't notice this skip - slip, but it is happening.
4WD should not be used on hard surfaced roads, driveline damage can occur.
RichF350V10
2002 4x4 AT SC Short Bed
Old May 23, 2002 | 03:55 PM
trixie's Avatar
trixie
IS THIS NORMAL
Like the others said, don't use 4wd on hard surfaces. As far as the pinging goes, not really sure what you are describing, but I'd definitely check the u-joints on the front drive shaft.
Old May 23, 2002 | 05:52 PM
thomasr's Avatar
thomasr
IS THIS NORMAL
RichF350V10
That's what I meant...well said!!!
REX
Old May 27, 2002 | 08:50 PM
Greywolf's Avatar
Greywolf
IS THIS NORMAL
Old May 29, 2002 | 12:21 PM
DUKHNTR4LFE
IS THIS NORMAL
yah thanks for the info i was on some pretty tuff dirt so that explains why it was skippin and hopin, and the pingin noise is only when i excelerate and only when its in 4wd but i will look at my front u joint have ne other ideas on what it night my
thank
dukhntr
