Sponsored by: Real Truck
Knock feeling in steering wheel
Old Sep 18, 2008 | 07:36 PM
jmaskew's Avatar
jmaskew
I have been noticing lately when I hit certain bumps in the road I feel a knock through the steering wheel. It doesn't happen that often but I'm starting to wonder. Could this be ball joints?
Old Sep 18, 2008 | 08:01 PM
boots6868's Avatar
boots6868
you dont say how many miles your truck got. Im thinking maybe tie rod ends? could use more info. is it worse when braking and cornering. did you do any after market lifting etc..
Old Sep 18, 2008 | 08:21 PM
jmaskew's Avatar
jmaskew
Originally Posted by boots6868
you dont say how many miles your truck got. I'm thinking maybe tie rod ends? could use more info. is it worse when braking and cornering. did you do any after market lifting etc..
It has just over 75,000 miles and no lift. What can I do to check the different components in the front end? I've never touched a front end before and would like to do the work myself....if possible. I did notice the knock once today while cornering (there was a bump) but mostly when it happens I am going over bumps that are in the streets around the Las Vegas area. Thanks for replying.
Old Sep 18, 2008 | 08:46 PM
rebelyell618's Avatar
rebelyell618
if it is a bad ball joint just jack up the front tires and rock the tire, if you have movement (as in a up and down motion) then that is usually a sign of a bad ball joint.
Old Sep 19, 2008 | 07:27 AM
jmaskew's Avatar
jmaskew
Thanks for the reply!
