Sponsored by: Real Truck
Speedo Recal
Old Sep 18, 2008 | 01:31 PM
Born Again's Avatar
Born Again
Speedo Recal
Can the computer on an 06 F250 be recalibrated for larger tires? If so...does a Ford Garage need to do it?
Thanks!
Old Sep 18, 2008 | 01:36 PM
riggz's Avatar
riggz
Yes it's actually done through the ABS module. I believe they can calibrate up to 35" tires or 600 rev per mile.
Old Sep 18, 2008 | 07:02 PM
Heavy_Metal's Avatar
Heavy_Metal
If you have bigger, you need to get an Accu-speed unit.
Old Sep 18, 2008 | 10:22 PM
brmpipes's Avatar
brmpipes
wouldnt your milage accumalate less with bigger tires.if so you just extended your warrenty by x% because of the non correction.Right?
Old Sep 18, 2008 | 10:26 PM
Born Again's Avatar
Born Again
Yes But...
Yes but my truck is just about out of warranty. I replaced the stock tires as they wore out...went to what are essentially 33" tires with no lift...looks really good this way. I checked my speed with a GPS and I am reading 2mph low...probably not worth worrying about.
Old Sep 19, 2008 | 09:16 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
I too have 285/75R16's which are around 32.8 inches tall. Stock was 31.6.
My speedo is now about 1 MPH low at 60MPH. Not enough to care about.
Just think how far it was off (on the high side) BEFORE the tires
Old Sep 19, 2008 | 09:20 AM
Born Again's Avatar
Born Again
Yup
I know! Based on GPS and those roadside radar units the DOT puts out, my speedo was about 2 mph higher than actual speed.
Old Sep 20, 2008 | 04:49 PM
Hootbro's Avatar
Hootbro
For liability reasons, most car makers have 3%-5% error on the high side built in. This is to keep you from suing or claiming liability to the car manufactures for your lead foot and speeding tickets.
Old Sep 20, 2008 | 07:06 PM
riggz's Avatar
riggz
yes, mine was this way until I had it fixed. I don't like it being off and not being able to correctly caclulate my mpg.
Old Sep 20, 2008 | 09:53 PM
brmpipes's Avatar
brmpipes
do you really get milage with a ford lol.
Old Sep 20, 2008 | 11:12 PM
riggz's Avatar
riggz
compared to a lil 4banger no, but I can get 19mpg+ on the highway with 35" tires. Plus I like to know if my mpg starts to drop of significantly as this would be a sign that something is not working properly.
