Downpipe back??
Old Sep 17, 2008 | 10:29 PM
stroke-of-luck00's Avatar
stroke-of-luck00
Downpipe back??
I think I'm going to cut off my existing stocker exhaust system and weld on a 4" straight pipe that turns down under the bed. my ? is....it is muuuuuch easier and cheaper to just get a straight 4" run and go from the down pipe back. will that still be a large improvement over stock or will the stock down pipe still hinder performance and EGT's?
Old Sep 17, 2008 | 10:35 PM
CAT_man_963's Avatar
CAT_man_963
Honestly - the stock downpipe is a lot of the restriction..... I see a tuner in your sig. - so I would say, you would be further ahead to do the downpipe too!
Old Sep 17, 2008 | 10:38 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Its wierd to see you posting again. Makes me feel like im reading a thread from 2005
Old Sep 18, 2008 | 12:33 AM
orng1's Avatar
orng1
Every section of exhaust is a restriciton. But the exhausts for these trucks are pretty cheap. If you can't afford it chop off the stock exhaust but I'd do a down pipe too if I were you.
