Question, should i adjust the headlights down a bit or am i ok????
Are you getting flashed by people? I like to keep mine as high as possible......without blinding people. A good indicator is if you're getting flashed in traffic. You'll sit a bit higher now also when you pull up behind somebody at a stoplight. Mine pretty much shine over their car when I'm that close lol.....Truck looks GREAT Bro!
Also Mike.....make sure you re-torque everything after a couple hundred miles!
I was going to say, just that. Primarily the u bolts if they were touched, remove the bumper to get the front spring hanger bolt at 205 lbs, and the rear shackle at 185lb-ft.
Not getting flashed yet, wooo hoo, lol. Haven't gotten it out yet at nite but will find out though. Thanks Travis, really pleased with the results..
Good deal fellas, will do, thanks. Didn't mess with the u-bolts but i will check the bolts for the shackle
Chris, Sanderson makes a few different shackles. 1.5" diesel, 1.5" gas, 2.5" diesel, and a 2.5"gas.
Thanks Brandon, I'll snoop around for members who have the 2.5" kit and get their thoughts. Not sure if I like the backward arch of the springs. I like how Mike's came out but it won't be tall enough to level the truck and I don't want to take out the blocks on the rear springs. Maybe a spring pack would be better fit for my application. I need to leave the truck at stock height since I pull my 5'ver.
