airbag indicator
Old Sep 17, 2008 | 06:26 PM
groho's Avatar
groho
airbag indicator
my scanner did not see any DTC's related to the airbag using the ODB port under the steering column. Understand the airbag is tied to another computer sys, is there another port? can it be ready using a ODBII scanner? Currently have an intermittent 32 code. Suspect a loose wire connection. Wanted to clear it to determine if it comes back. Sorry, 96 ford explorer.
