Ball Joints....................
Old Sep 17, 2008 | 01:34 PM
Vinford's Avatar
Vinford
2002 F-350 4x4 PSD
So Im attempting to get to my ball joints which are worn badly.
Ive taken all the brake stuff off and the hub is out.
4 big bolts from the inside next?
Anything i should be aware of ?
After i get those 4 bolts out is the whole hub assemble going to come out including the axle?
Old Sep 17, 2008 | 01:53 PM
Vinford's Avatar
Vinford
Got it down to taking out the axle.
What holds the axle in ?
It seems to be wiggling around but doesnt come out?
Old Sep 17, 2008 | 01:58 PM
just another truck's Avatar
just another truck
I believe those are held in by c clips, you would have to remove the spiders in order to get the axle out
Ponyboychris's Avatar
Ponyboychris
Maybe this will help:
Ball Joint Installation
Old Sep 17, 2008 | 02:10 PM
Kwikkordead's Avatar
Kwikkordead
Get in behind the U-joint yoke and pry outward, firmly.
That will release hold that the big outer seal has on the shoulder and the axle will pop right out.
Old Sep 17, 2008 | 02:15 PM
USAF CCM's Avatar
USAF CCM
What Timing? Bad wheel bearing!
Sorry if this is a hijack. My wife and I were on our way to BTS last night when I suddenly heard the sound of driving on the shoulder rumble strip...............I wasn't driving on the shoulder!!!! Then we heard the sound of light intermittent metal grinding.
I immediately got off I-44 still in St Louis (it was a blessing we were only 50 miles from home) to check out the truck. Tires looked good and inside I kinda knew what it probably was so I felt each rim.....my right front rim was almost too hot to touch. I jacked it up and spun the wheel; I found my grinding metal noise and it wasn't the brake wear indicator.
So $235 lighter we got roll-back towed to the driveway. So now after finding out that the Ford OEM sealed bearings are approximately $350 EACH, I'm leaning towards replacing everything with the Dynatrac Free Spin set-up and replacing all the ball joints since I'm in there.
Here's the question: Which are working out best? The Moog kit from powerstroke shop, NAPA Golds or Dana's; all with grease fittings. I've spent the last four hours reading the ball joint posts but would like a fresh opinion. Thanks as always! V/r Les
Old Sep 17, 2008 | 03:00 PM
Vinford's Avatar
Vinford
Did it vibrate to start with?
Thats what mine is doing?
I dont think the ball joints are making it vibrate but they had to be done while Im looking for whatever else is making it vibrate.
Old Sep 17, 2008 | 03:38 PM
USAF CCM's Avatar
USAF CCM
No vibration. The sound started immediately after turning onto I-44 from the I-55/I-44 split in St Louis and was unmistakable. We just finished taking three long trips and didn't notice anything previous. The day prior we picked up a heavy load of firewood so who knows.....we're just glad it didn't happen in no mans land. That's why I want to go through the entire front end.....once. V/r Les
Old Sep 17, 2008 | 03:57 PM
randomhero1172's Avatar
randomhero1172
Ball joints are a PITA!!! Ive been putting off mine for a while, short on time and $! goodluck with everything
Old Sep 17, 2008 | 04:26 PM
Vinford's Avatar
Vinford
Got one side in..........had to go for parts and had lunch and it still only took me 3 hours all inclusive.
Old Sep 17, 2008 | 06:57 PM
Orezona's Avatar
Orezona
That's what I used.
Old Sep 17, 2008 | 07:05 PM
totin_tools's Avatar
totin_tools
Both times when my hub bearings went out the abs light came on in the dash. Then the grinding started a while later.
Old Sep 17, 2008 | 10:20 PM
USAF CCM's Avatar
USAF CCM
Wish I'd of had an ABS light, but it could've turned out much worse. In the big scheme of things $235 will be forgotten. Anyone have an opinion on Dynatrac Free Spin and ball joints? Thanks!
