how much clicking is normal?
Old Sep 16, 2008 | 11:10 PM
bigsteve1969's Avatar
bigsteve1969
here latley this clicking has been getting to me. ever since i put my 4" magnaflow stuff on im hearing more "noise" from the motor. a buddy of mine conviced me its only valve chatter that changes with the back pressure created by the new exhuast.. the magnaflow mufler didnt have a inlet stamp on there so could it be on wrong causing to much back pressure? its mainly just sounds like a pinging noise. im gonna pull it up to the shop tomorrow at school and let the instructor hear it and see what he thinks... im thinkin about just pullin the diablo off and runnin stock if programming is gonna mess this motor up.... i'd preciate the help! oh and i listend to a buddys 7.3 and it sounded nothing like mine im assuming because of my intake and exhast is that pretty safe to say? im gonna order a hpx sometime this week and hope it can clear some of it up what do yal think
Old Sep 16, 2008 | 11:30 PM
nhill2090's Avatar
nhill2090
If you have the long lead #8 injector, it is not uncommon to hear a noise similar to hitting a ball peen hammer on the frame
Old Sep 16, 2008 | 11:32 PM
bigsteve1969
mines a late 99 so would upgrades like i have minus the ccv ( i put it back stock to see if it affected my blowby out of fill neck) cause it to be MORE noticeable
Old Sep 17, 2008 | 10:20 AM
Smokin''s Avatar
Smokin'
Smokin
I have a clicky #8 too. It's annoying, but no cause for alarm
Old Sep 17, 2008 | 10:41 AM
white Buffalo's Avatar
white Buffalo
The HPX line might help smooth out the idle a bit but won't necessarilly quiet up the chatter. The mod that quieted the engine cackle the most was the in-tank & pre pump mod.
Here is an example:
ITP 7.3L Fuel Tank / Pre-Pump Kit
http://guzzle.rbmicro.com/hutch.html
Also, a regulated return but I would do the in-tank & pre pump mods first
Old Sep 17, 2008 | 04:14 PM
bigsteve1969
well today at class i pulled the valve covers (kinda a biotch) and re tq'd drivers side only and it helped a little but i got to lookin around and my exhaust back press. sens. was cracked so i pulled it off and it was clogged again!! so i went to pull the tube and pop it broke it was rusted in two... well i didnt have the $$ to buy a new one from ford so me and my instructer made one out of "custom" bent brake line 2.67 for 4ft of brake line. so that threw away my "to much exhast backpressure" code but i still have to get that sensor when i order my hpx.
Old Sep 17, 2008 | 04:30 PM
nhill2090's Avatar
nhill2090
Very nice. Once you have done it a couple times, its gets easy. I have it down to about 10-15 mins/side.
Old Sep 17, 2008 | 04:33 PM
bigsteve1969
well that last bolt on the back is a PAIN ha ha i looked at the left side and said forget this ha ha too much stuf to remove
Old Sep 17, 2008 | 04:51 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Yeah, the passenger side looks pretty daunting. What setting are you running around in on the Predator?
Old Sep 17, 2008 | 05:28 PM
bigsteve1969
60 economy
Old Sep 17, 2008 | 05:46 PM
Powerstrokedlariat
Mine got a little noisy in that setting as well. Any chance of a sounds clip or youtube maybe to help better?
Old Sep 17, 2008 | 05:49 PM
bigsteve1969
yea im gonna try and take one in a little bit but im tryin to find a site that i can buy a sensor and hpx from
Old Sep 17, 2008 | 06:54 PM
Powerstrokedlariat
KCM S.S. HPX Line (99-03)
I recommend this for the hpx. Good service here as well.
Old Sep 17, 2008 | 09:56 PM
nhill2090's Avatar
nhill2090
THe passenger side really isnt that much more difficult than the drivers. And the back bolt isnt nearly as tought. Best thing I have found for back of drivers is a 13mm with a wobble and 6" extension on a 3/8 drive ratchet.
Old Sep 17, 2008 | 09:59 PM
zack7.3's Avatar
zack7.3
That is exactly what I used. The passenger side was easier, I thought. The only tough one is right underneath the AC evaporater box. Easy to get it out, but a pain to get it back in. I actually had to have my wife use her small hands to get it in since I have some big sausage fingers.
