Sponsored by: Real Truck
Reverse Sensing System problem
Old Sep 15, 2008 | 09:13 PM
larmon's Avatar
larmon
I have a problem with my Reverse Sensing system on my 2006 F-250. It quit working. As soon as I shift into reverse, the OFF light illuminates in the switch and will not shut off. If I move the shift select to any other position, I can get the OFF light to extinguish by pressing the RSS switch twice. But as soon as I shift to reverse, it will come back on. Unfortunately the Warranty expired in June, so I'll have to pay out the nose if I take it to Ford.
Does anyone have any ideas what the problem is?
Old Sep 15, 2008 | 09:46 PM
donjamer's Avatar
donjamer
Not sure what the problem is, but I think most of the issues are caused by faulty sensors.. Have you backed into anything??
They may look fine, but they could have a hair line crack..
My SIL had an issue with them cracked on her Honda MiniVan.. They replaced the sensor and all is well..
There may be a meter check for them, but again I am not sure..
Hopefully someone else will pipe in
Old Sep 15, 2008 | 10:07 PM
FTX's Avatar
FTX
Get someone to scan the DTC codes for errors, if it has error codes it will at least point you down the right path to fixing it.
Old Sep 16, 2008 | 09:51 AM
socalduner's Avatar
socalduner
It is a faulty sensor, My truck had the same problem. I dont know how to tell which one is bad because mine was repaired by the dealer under warranty. I would bet you could get one and test it in each position until it works.
Old Sep 16, 2008 | 11:34 AM
bdb2047's Avatar
bdb2047
Check this on E-BayItem number: 300257740342.I bought 2 and changed them till i found bad one
Old Sep 16, 2008 | 03:31 PM
mrisvs's Avatar
mrisvs
Just had the same prblm on 08 SD, dealer replaced speaker for reverse sensor system and all is well. Had the same symptoms. Good luck
Old Sep 16, 2008 | 06:04 PM
larmon's Avatar
larmon
Thanks for all of the replies. I decided to take my pickup to the dealership today and let them check it out. They just called and said that the sensor on the right side is bad. They said that it didn't look like it had gotten bumped, so it likely just went bad. I am going to let them replace this one, but if it happens again, I think I am going to change it myself. The Service Advisor that I talked to said the the RSS is very reliable. I sure hope so.
