Offroad & 4x4
lifting
Old Aug 17, 2002 | 12:03 AM
ridin_high_2003's Avatar
ridin_high_2003
lifting
Ihave truck that i would like to put a 2-3 inch lift on for a friend its 2 wheel drive automatic ranger.But it has a cable linkage and my friends havent ever lifted something like that if any of you guys know how to do it please give us a little help. we also need to know if there is a certainlift kit he needs to get for that style.
Thanks
Tilley
Old Aug 18, 2002 | 06:04 AM
MustangGT221's Avatar
MustangGT221
lifting
Can go to superlift.com or skyjacker.com and check out their kits, and buying one from ntwonline.com. Your other option is a body lift, but that will make gaps between the bumpers and the body (they make small kits to cover them, but doesn't look great). Also, the body lift will make it easier to see the frame, which isn't always cute (like on a chevy).
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Old Aug 21, 2002 | 01:44 PM
jberylecrider's Avatar
jberylecrider
lifting
Go with the body lift!
Its only $100 and very easy to install.
The cable linkage makes things easier!
You can move the front & rear bumpers up to get rid
of the gap. Look at my gallery, I have a 3" body lift
with no gaps!
Good luck!
Old Aug 21, 2002 | 04:46 PM
MustangGT221
lifting
Yeah but what about the frame, you can see it easier. In many opinions, not just mine, they are the cheaper way to go, but not as good as a suspension lift.
Then theres:
99' Mustang GT 4.6L
Old Aug 21, 2002 | 08:35 PM
ridin_high_2003
lifting
Thanks for your guys input he has the lift kit now and all he is waiting on is to get the tires and yes he is going with a body lift simply because it will be easier to install.if any one else has any pointers on how he should put it on go ahead and lets us know .
Thanks
Tilley
Old Aug 21, 2002 | 08:57 PM
rebocardo's Avatar
rebocardo
lifting
Make sure the lift comes with a bed lift as well. Buy your torx bit (if your bed uses them that year) from Sears (or better Snap-On) so if/when it breaks you can get a replacement for free/easy.
The "impact" ones from Autozone etc. are very weak and will probably shear off inside the torx bolt if they are rusted, which can be a major hassle. From personal experience.
Disconnect your battery (mostly for the airbag). I think on the 91 Ranger they have a battery backup but it only lasts a minute or so.
Old Aug 21, 2002 | 11:06 PM
jberylecrider
lifting
You keep bringing up the "frame" it is only a problem on ugly chevy's NOT on FORDs. You can barely see the frame on a FORD with a 3" body lift. Especialy if there is no suspension lift, because the truck is still too low to the ground to notice it.
I have major lift and I dont notice the frame, it looks fine to me. Take a look at my gallery. My truck with a body lift has the same amount of frame rail showing as a newer stock chevy!
You can even get or make gap gaurds for inside the fenders to hide the gaps between the frame and body.
The FRAME is not a problem in my opinion.
But I do see why it would be a ugly problem on a chevy.
Old Aug 22, 2002 | 11:50 AM
D Ray's Avatar
D Ray
lifting
jberlecrider,
Did your body lift come with a bracket to raise your rear bumper? If so, who makes it. I'm looking for a body lift but can't seem to find one with the rear bumper bracket.
By the way, nice truck!
Old Aug 22, 2002 | 12:11 PM
jberylecrider
lifting
There are no bumber brackets front or rear for our era of Fords.
For the rear you just take the bumper off, measure 2.5" up from the stock holes and drill new ones. Bolt the bumper in the new holes. All done.
For the front its a bit more difficult because the bottom of the bumper curles under the frame rail. You have two choices here:
1. Cut a notch in the bottom tip of the frame rail 2.5" back and 2.5" up. The bumper can then be mounted higher on the excisting mounts.
-or-
2. Cut a notch in the bottom of the bumper in-line with the frame rails so it can be raised without the frame rails getting in the way.
Either way its not very hard to do, you'll probably spend a day doing it all. We used a sawzall and notched out the frame rail for the front on my truck. I think it looks better, because if you just notch the bumper itself you will see the bottom of the frame rail sticking out of the bottom of the bumper.
Anyhow, I'd be more than happy to help you out. Just email me or something.
Old Aug 22, 2002 | 09:43 PM
MustangGT221
lifting
I thought body lifts were a PITA to install...suspension kits are cake. Am I wrong?
Then theres:
99' Mustang GT 4.6L
Old Aug 22, 2002 | 10:37 PM
jberylecrider
lifting
Depends on the truck...
A body lift on this '91 Ford is EASIER than a suspension lift on this truck.
But if you are comparing this install on this truck to a suspension lift on an older solid axle model then yes the suspension lift is easier on the older model than the body lift on this newer model.
The newer the 1/2ton truck, the more difficult the suspension lift is, but the body lift is still easy.
Nothing beats the old trucks though, everything is easier!
I have done body lifts on everything from a 72 Chevy to a 94 Ranger and of coarse my truck
Most of the time the body lift is A LOT easier.
Old Aug 23, 2002 | 10:18 PM
MustangGT221
lifting
I've heard they were a PITA because of the bolts being stuck, and the shifter linkage and crap. I bet it's easier with power tools, but i still like suspension lifts better. I wouldn't put a body lift on there unless i had an 8" lift and needed more.
Then theres:
99' Mustang GT 4.6L
Old Aug 24, 2002 | 12:37 AM
RBrendel's Avatar
RBrendel
lifting
i have 3 inch body on my ford and it has been great, no complaints here, i would do it to any of my trucks even a brand new one.
Old Aug 24, 2002 | 07:56 PM
Ruthy's Avatar
Ruthy
lifting
Justin.Hoeben
Nov 27, 2013 12:44 PM
rat49f6
1997 - 2003 F150
Jul 29, 2009 12:03 PM
94btfrdtuf
Offroad & 4x4
May 3, 2004 08:32 PM
FordPickup460
Nov 28, 2003 12:09 AM
93bigbronco
May 4, 2001 10:45 AM
