seats
Old Sep 15, 2008 | 06:13 AM
dutydave's Avatar
dutydave
seats
I just purchased a 1995 4x4 regular cab and I am in need of a new seat. Up to what rear will the ranger/ explorer seats fit in these trucks without any modifacations.
Old Sep 15, 2008 | 05:27 PM
Rangerman Stan's Avatar
Rangerman Stan
You might be able to fit newer seats in yours all the way up to about 99 or 2000 with the Explorer or Ranger. Or maybe even newer with the Ranger. Keep in mind that if the sliding part of the frame doesn't fit your floor contour or bolt hole pattern, you can unbolt the seat frame from the sliding frame to change just that part to the other seat. Not sure if the standard cab floor contour is the same as the supercab around the mount holes. I've only dealt with the supercab on this issue.
Old Sep 15, 2008 | 06:57 PM
wendell borror's Avatar
wendell borror
I believe rangerman Stan about summed it up for you.
Old Sep 15, 2008 | 08:42 PM
dutydave's Avatar
dutydave
thanks guys
