Offroad & 4x4
4x4 conversion questions
Old Aug 23, 2002 | 12:36 PM
deere81's Avatar
deere81
I posted this in the transmission, axle forum and didn't get any replies. I came across a 1980 F-350 SRW 4x4 that is for parts. The engine, transmission and transfer case are all missing. I was wondering what the TTB front end and the rear end would be worth. I think the guy wants $100 for both axles with springs and spring hangers included. I thought about converting my 2wd F-150 to 4x4. I would rather have a dana 60 monobeam front axle, but I think the TTB would basically be a bolt in conversion. I also found a '80-'86 F-250 light duty 4x4 at the same place which i think could be bought for around $400. So I also thought about buying that truck and putting the F-350 axles under it. I would like to have a 4x4 farm truck that i could also use in truck pulls.
'90 F-150 351 AOD "The General"
'78 f-250 460 C-6 "Old Green"
'93 Mustang 5.0 AOD
'88 Jeep Cherokee 4.0
Old Aug 23, 2002 | 03:12 PM
MustangGT221's Avatar
MustangGT221
If it's an F-350, it has solid axles up front, d60s. If it's a light duty F-250 than it has a TTB d44 up front. If it's a supercab or heavy duty F-250 it's a d50 up front with bigger brakes and hubs.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
Old Aug 26, 2002 | 09:27 AM
deere81's Avatar
deere81
I know that the newer F-350's have a solid dana 60 front axle, but this is a 1980 F-350 with a TTB frontend. What are the F-350 axles and the F-250LD 4x4 worth?
'78 F-250 460 C-6 "Old Green"
'93 Mustang 5.0 AOD
Old Aug 26, 2002 | 10:58 AM
MustangGT221
The old 350s came with TTBs? wow, sorry my mistake.
Then theres:
99' Mustang GT 4.6L
Old Aug 26, 2002 | 11:06 AM
deere81's Avatar
deere81
Yeah this one has a TTB, It is the second one that I have seen. I had an uncle who had a '80 F-350 with a TTB frontend. I used to think that all trucks 80 and up had TTB until I started noticing that '87 and newer F-350s with solid front axles.
'93 Mustang 5.0 AOD
Old Aug 26, 2002 | 03:01 PM
MustangGT221
Well, I guess you learn something new everyday, sorry to be of no help.
Then theres:
99' Mustang GT 4.6L
Old Aug 28, 2002 | 11:58 PM
hillbillyk's Avatar
hillbillyk
80-85 f-350's have the ttb, ford realized they screwed up and put the straight axle back in in 86.
Old Sep 10, 2002 | 10:31 AM
deere81's Avatar
deere81
Can anyone answer my question, and tell me what the axles and donor truck should be worth?
'93 Mustang 5.0 AOD
Old Sep 10, 2002 | 12:03 PM
MustangGT221
You said you want it for farm pulls, so I assume you want something really strong. The light duty F-250 TTB is simply a dana 44 with leaf springs vs the F-150s coil springs. I'm not 100% sure what the 350 back then was, but i bet it's stronger, so if those parts are in good shape, I'd say go for the 350 parts in the F-150. Now if you want the 250 and put the 350 parts in it, than sure if you don't want your 90' F-150 to have 4x4. So basically the choice is yours but if they are in decent shape those are cheap.
That's it for mods now, saving for a Stang. Check out my Gallery for a look-see.
Old Sep 10, 2002 | 04:53 PM
deere81's Avatar
deere81
I didn't think it was that bad of a price, but, I wanted another opinion.My original plan was to use the F-350 axles under my F-150, and then use the C-6 and transfer case from the F-250LD since that was missing on the F-350. If I ever get the time and extra money I might go ahead and try to do the conversion.
'93 Mustang 5.0 AOD
Old Sep 10, 2002 | 09:16 PM
MustangGT221
Go for it we can help you along the way.
Old Sep 10, 2002 | 10:34 PM
kiksomepoo's Avatar
kiksomepoo
where is this... I need a TTB :-X12
Old Sep 13, 2002 | 07:41 AM
jalampi's Avatar
jalampi
nick406
Jul 21, 2004 08:52 AM
billy87
Jul 17, 2004 04:50 PM
eckart
Apr 11, 2003 12:58 AM
slimersoup
Offroad & 4x4
Jun 9, 2001 12:17 PM
