help with trailer capacity
Old Sep 14, 2008 | 11:51 AM
edub32's Avatar
edub32
well im buying this 5300 lb diesel tractor and was wondering if this trailer will hold that well. the owner of the trailer unfortunately doesn't know much about the trailer and i dont really know much about trailers either. just by looking at it what do you guys think the towing capacity would be. also what can i look for on the trailer to make a rough determination of the capacity.
do you think $500 is a fair price?
Old Sep 14, 2008 | 11:58 AM
ron's power stroke's Avatar
ron's power stroke
looks like its worth 500...im sure it would hold up but need pics of the springs and what kind of the tires to see how much it could hold....
Old Sep 14, 2008 | 12:08 PM
Tecman's Avatar
Tecman
Its all about which axles are under it. typically the lowest axles they put on a tandem axle trailer are 3500#s each so a total of 7k. that trailer might weigh about 1500# max which would leave you about 5500#s to carry the tractor so you should be fine. I would bet the axles on that equioment trailer have a higher rating than dual 3500# axles since they are typically made to carry skid steers and such
Old Sep 14, 2008 | 12:09 PM
totin_tools's Avatar
totin_tools
how many lugnuts are on the wheels? Check the tires like Ron said for capacity weight. Also what size ball is it? Alot of the heavier trailers use a 2 5/16 ball.
Old Sep 14, 2008 | 12:11 PM
Tecman's Avatar
Tecman
Also there SHOULD be a tag on it somewhere. most likely located between the ball and the front of the trailer. It will list the weights and capacities as well. It looks older so it may be missing. The tags are typically rivited on though.
Old Sep 14, 2008 | 12:34 PM
white Buffalo's Avatar
white Buffalo
How thick are the crossmembers under the deck. 1/8", 5/16", 3/8"?
Old Sep 14, 2008 | 12:58 PM
megawatt00's Avatar
megawatt00
$500 is a good price. If you can get him to knock a bit more off even better. If the trailer is too small for your needs, buy it anyway clean and paint it up and sell it for a profit. A little bit of TLC can go a long way when it comes to $$$$.
Old Sep 14, 2008 | 01:20 PM
bigsteve1969's Avatar
bigsteve1969
ive been looking for a trailer about that size but in my opinion it looks like a car hauler because its low low ha ha but check out like they said usually they put a tag on the frame somewhere that states max capacity and stuff but i do think that 500 is a fair price plus a 100 or so in paint and wood coat and you could probabbly make some profit off of the thing
Old Sep 14, 2008 | 04:29 PM
hucka1a's Avatar
hucka1a
^^^^^^^What they said^^^^^^ Also, I'm not sure. But if their is a title for this trailer, it might tell the weight capacity.
Old Sep 14, 2008 | 04:34 PM
megawatt00's Avatar
megawatt00
Good idea Huck, maybe the registration also.
Old Sep 14, 2008 | 06:19 PM
danskool's Avatar
danskool
Go Bills !
I have done that many times. Wish this trailer was close to me, I'd be backing up to it, Fixing up and reselling. Trailers sell like hot cakes. Especially ones that have fresh paint.
Old Sep 14, 2008 | 07:13 PM
megawatt00's Avatar
megawatt00
The old saying is so true: Putty and paint make it what it ain't
Old Sep 14, 2008 | 07:38 PM
white Buffalo
good one
Old Sep 14, 2008 | 10:44 PM
jhand124's Avatar
jhand124
I think it's maxed at about that, if you look at the frame from the bed to tougue, it is pretty thin not much of an I-beam there. 7000# gross is my estimate.
Old Sep 14, 2008 | 11:35 PM
willeo6709's Avatar
willeo6709
part of your answer will be how often you plan on hauling it around. If its for work and you plan on dragging it around 3 days of 5 for the next 5-7 years, consider something heavier IMHO, if you are dragging it home or pulling maybe 1 every week or couple of weeks, buy it, change the tires, and be happy. Why change the tires you ask? Tires fail due to degradation of the steel belts. this degradation takes place regardless of tire mileage and is mostly proportional to tire age. I have pulled trailers with very very old tires. I have ripped them apart in the middle of 3 lanes of bumper to bumper traffic at 65 MPH too( with a 5300 LB machine tool sitting centered on the axles). That little episode cost me a rim as well, but I got lucky and did not hit anyone else with the trailer when it happened. RV'ers say to change the tires every 3 years I think... that may be a bit extreme, but if you pull alot and dislike changing tires in bad places, put new rubber on it, especially when pushing the trailer capacity in the first place.
